E34 (1989 - 1995)
Old 01-05-2013, 02:00 PM
95.525i 95.525i is offline
Mein Auto: 1995 525i
1995 525i WON'T START
Recently purchased a '95 525i that has been sitting for a few years. Bought the car started fine, i believe all the locks went up and down when using the trunk/driver's door. It came with one key, it did not come with a remote-button key to work locks. Car started and drove fine (275k+ miles) for about 2 weeks then went to move it on street sweeping day and the car would not start. I put the key in and all the lights turn but the car would not crank, i would just hear a click coming from the back (I suspect from the anti-theft box under the left backseat). Also i sometimes hear like a "grrrr-ing" noise sometimes when i try and start it, could it be a fuel pump problem ? Although after it didn't start i messed around with the locks (as a friend told me to do) and i locked/unlocked the doors from the drivers side and trunk. Waited about an hour and the car started up fine. Drove it and parked it and went to go start it again and wouldn't start. Thought it had something to do with the locks but then it wouldn't start for about a month, no matter what i did to it (I put new spark plugs in it, got another key made for it and gave it a new battery since the old battery was dead). And still would not start. After about a month of trying it for some reason starting again, took the opportunity and drove it down to a friend's shop to get it diagnosed by a computer and the computer read it had a voltage reading problem (already had new battery in when tested) and it couldn't read "Key 5 and 6". I drove it home, waited until nightfall, tried it again and wouldn't start. Could these things be the problem, I don't understand why it would work for a day then not for 3 weeks. ALSO, when i put my key in to unlock the driver's side door the lock does not go up or down, it just stays constantly unlocked and none of the other locks in the car respond, only the backseat left lock when i put the key in the passenger side door, the drivers side window doesnt roll up or down just came off the tracks and also the anti-theft light flashes until i put the key in. Could the lock system be the problem ? WHY would it work for a few hours then not work for many days, could it be a fuel problem (from that grr noise i hear sometimes when i try to start it) or a problem with the anti-theft system ?
Old 01-05-2013, 05:04 PM
Mein Auto: 1989 525i M20B25
I didn't read your whopping paragraph, but I can tell that this is an EWS problem.
Old 01-05-2013, 06:15 PM
Banned
Mein Auto: car
Please reexpress your whopping paragraph using the usual rules of English grammar, to permit assimilation by readers, and thus prompt responses to you to help you solve your issue.
Old 01-05-2013, 10:33 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
this
also this: http://www.bimmerfest.com/forums/showpost.php?p=6594370
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 01-06-2013, 09:07 PM
BMWFatherFigure's Avatar
Old School
Window jumping off tracks stinks of theft attempts. Damage to the lock electrics or its connectors?
Current:
E38 Parts Car
Previous:
Old 01-08-2013, 06:14 PM
525iclassicguy 525iclassicguy is offline
Mein Auto: 89 525i BMW
I have the same problem my car turns over like it wants to start but there's no fire but everything on the car is good we even change the coil pack but the car starts every now and then
Old 01-08-2013, 06:37 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
Have you checked the crankshaft position sensor?
Fuel Pump
Fuel pump relay
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 01-08-2013, 06:45 PM
I check everything but the fuel pump relay its just funny how its start out of the blue sometimes
Old 01-08-2013, 06:57 PM
Swap the relay out with a same colored one from the fusebox.
If you don't know which relay is your fuel pump relay, pull the relays in your e-box one by one with the car running and see which one makes it slowly stop running.
