E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
#26
I think I'm with steve on this also. The only reason he even posted anything about the dipstick is because the op did.
He didnt just hear some random question and say "check your dipstick" Steve knows alotb about these cars and knows that the fpr is very much near the dipstick. When the op asked a very vague question with little detail... And bare with me here if with little information someone said they think their fpr is bad and smell gas on the dipstick and didnt confirm the exact place of smell. Most anyone who owns a m20 engined e30 probably would have assumed the same |
#27
you can keep distorting what i've said. others can see what you're trying to do, so i don't need to keep confirming what i've said to be completely possible.
if you want to lead the orchestra, you must turn your back on the crowd ![]() build: http://www.bimmerfest.com/forums/sho...d.php?t=382667 |
#28
Pm sent already...ghost.
#29
Just like everyone else who rides steve's (fill in the blank) i have already stated that yes he does know a good amount about these cars. Im not taking away from that. But he comes off as rude a lot and its really not needed. Period
#30
![]() I would assume guy's problem is fixed or he's trying to fix it now... we'll see shortly I guess.
1985 335i ![]() Black on Black coupe 5spd Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap http://www.bimmerfest.com/forums/sho...36#post7573736 M20B27 for sale in Cincinnati |
#31
I know a lot about cars. I can look at a car's headlights and tell you exactly which way it's coming |
#32
To clean fouled plugs you can try throwing them into your hot BBQ coals, or use up half a lighter with full-flame at the tip of the plug
![]() It does not always work, but as I come from the dark ages where we often rode our 2-stroke bikes home from the pub, early in the morning in Winter (yes we can get -C temperatues in Africa ![]() If you are in doubt about your plugs > replace them or are they that expensive on your side
@nicholasb
Did you ever get your problem fixed? Did you check the fuel pressure? If the fpr doesn't fix your issue, you should also look at the cold start valve and injectors. Check the cold start valve or injectors' ability to hold pressure after the car has been turned off. Leaky injectors drain fuel directly onto the piston and in the oil. This might be the cause of the fuel smell on your dip stick.
Big Boyz with Bad Toyz. Last edited by BigBoy740il; 02-07-2013 at 07:26 PM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
