Continuous power (lighter plugs) - Bimmerfest - BMW Forums
Old 01-06-2013, 11:42 AM
Anonimac Anonimac is offline
Mein Auto: BMW 550i
I'm not a smoker so i'd like to just equip all the lighter plugs with low profile plugs (for usb chargers) so that I, and my passengers, always have charging options.
However...it looks to me like the one i've started using so far (in the cup holder) always stays on. That concerns me related to battery drain.
Can someone confirm if all the lighter plugs are continuous power? I'd like to just leave certain things plugged in and not have to unplug each day. Is there a workaround? I read on one forum that the passenger footwell one is NOT continuous; can anyone confirm that?
2014 BMW 550i (Alpine White) | M-Sport | 20 inch 356's
Old 01-06-2013, 11:45 AM
ausdude's Avatar
ausdude ausdude is offline
Mein Auto: 2013 BMW 550i M-Sport
Hmmm.... I would like to know as well. I have had 2 installed for about 2 weeks and no issues with battery drain yet. My guess would be if you do not drive it everyday you may want to unplug them. But no issues here
Old 01-06-2013, 11:55 AM
jpmf10 jpmf10 is offline
Mein Auto: 2012 528xi
They should turn on when you open the door or when the car is on. After the car is off, they take 10 to 15 min to turn back off. You may want to get in the car, shut the door and wait for 15 min. When you check the outlet, it should now be off. I believe this is the same for all the outlets YMMV.
Old 01-06-2013, 05:29 PM
Mein Auto: BMW 550i
It would be great if this is how it works. I understand the need for maybe on outlet to be continuous power for something like trickle charging, but it's super dumb for them all to be like that. If anyone knows definitively let us know.
Old 01-06-2013, 06:42 PM
markl53's Avatar
markl53 markl53 is offline
bimmerfest Supporting Member
Mein Auto: 2014 535i
Attached from my 2011 535i manual. It states that power is available at the "sockets" when the engine is running or ignition it switched on. Other areas of the manual talk about ignition swithing off. After approximately 8 minutes, or when vehicle is locked, if you haven't already pressed the "STOP" button twice to totally shut down the car. I've used the front socket to power my tire inflator, but honestly have never tried it after initially opening the door without having started the car. Seems like a simple test you can try.
BMW-CCA
Bimmerfest Supporting Member
2014 535i Individual | Azurite Black/Amaro Brown Merino | Premium | Cold | PDC | Rear Camera | Anthracite Hdr
Prior: 2011 535i AT | Black Sapphire/Cinnamon | Premium | Heated Sts | Nav | Sirius | Anthracite Hdr & Trim
Prior: 2008 335i 6MT Sedan | Black Sapphire/Terra Leather | Premium | Cold | CA | OEM Alarm
Prior: 2005 330i 6MT | Black Sapphire/Sand Leather | Premium | Cold | UGO | OEM Alarm
Old 01-06-2013, 07:05 PM
yogi799 yogi799 is offline
Mein Auto: '11 535i, '99 328i retd
I can confirm that they stay on for about ten minutes after the ignition is turned off.
2011 535i F10 delivered
1999 328i E46 retired
Old 01-06-2013, 07:07 PM
I have devices which are always plugged in and I can sleep well. I believe the sockets are on for about ten minutes even after the doors are locked.
Old 01-06-2013, 07:30 PM
Volcano375 Volcano375 is offline
Mein Auto: 2012 528i xdrive
Where can I get those original BMW USB/lighter converter, and how much?
Old 01-07-2013, 06:37 PM
Donm's Avatar
Donm Donm is offline
Mein Auto: '13 M 550i, BMW f800st
Not BMW but low profile. Scoche seems to make good stuff.
http://www.amazon.com/Scosche-USB12V.../dp/B002ZXB7KW
Best regards,
Don M
It isn't broken yet but I can fix that!
2013 550i Titanium Silver Metallic Dinan S3 , BMW F800ST, ML350
Old 01-07-2013, 07:32 PM
Mein Auto: BMW 550i
Just my 2 cents... i'm a mixed user (some android, some apple, some other) and there is nothing like this charger.
http://www.thinkgeek.com/product/eea9/?srp=3
Smart tech that detects the circuit requesting power and enables "fast charge" for each so that you're rapid charging in the AC profile (vs. USB) and support 3 amp spike to revive the biggest and newest tablets (e.g. latest iPad).
