Old 01-06-2013, 11:46 AM
nitrydr1600 nitrydr1600 is offline
Mein Auto: 1997 z3, 1982 corvette
1997 z3 motor swap
1.9 engine. does a engine factory equipped with auto trans work putting into a manuel or is there issues such as no hole drilled in crank or something crazy for manuel trans. just want to be sure before i start this project
Old 01-06-2013, 12:18 PM
vintage42's Avatar
vintage42 vintage42 is offline
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Could there be more issues besides the physical bolt-on replacement of an automatic transmission with a manual transmission and its linkage?
Is the automatic transmission electronically controlled with a TCU?
Does the automatic transmission require a different ECU than the manual transmission?
Does the automatic transmission need changes to the radiator for fluid cooling?
Old 01-06-2013, 02:59 PM
z3 is manuel and putting new motor in that came out of an automatic is my question
Old 01-06-2013, 03:03 PM
marty505 marty505 is offline
Mein Auto: 99 Z3 M Coupe/99 540i
The engine will bolt right up, no problem there. Keep the DME that was originally in the Z3, don't use the 318 DME. I'd be tempted to swap as much of the 318 engine harness as possible right up to the DME connector - providing the DME system is the same (The P/N is the same right? and if not exactly the same at least the same Motronic version right? Sometimes the DME P/N changes are physical changes to the case not the guts) That link to the Pelican Parts site in the earlier post is helpful for determining software/hardware versions among the various E36 electronics. I admire your determination, I hope this works out well for you. Jumping into a basket case BMW is a tough way to learn the car.
Old 01-06-2013, 03:10 PM
hey thanks. motor is half way out of the donar in the snow BUT i refuse to let it kick my ass for at least another thousand bucks
Old 01-06-2013, 03:52 PM
You're pulling an engine outdoors, in Michigan, in January? That's pretty hardcore.
Old 01-06-2013, 03:55 PM
im a snowmobiler lol u can keep the heat to a point!
Old 02-07-2013, 11:00 AM
done deal......now the wait till spring. cant figure out how to post pic. though
Old 02-07-2013, 04:51 PM
So it started up and ran OK? No Check Engine Light or other weird problems?
Old 02-07-2013, 05:01 PM
all good. new chrome wheels roll bar etc. i actually drove it lst week. 9 miles. Awsome car the way it handles. bad way to start but very happy and actually just put my vette up for sale! A little work never hurts anyone. Just cant wait for the snowstorm to get over!
Old 02-07-2013, 06:52 PM
That's great - congratulations on a job well done!
