Old 01-06-2013, 01:32 PM
Takechan Takechan is offline
E39 fanboi
Mein Auto: BMW E39 520i (M52B25)
Bosch Alternator Rebuild Success!
Hi,
Inspired by cn90's Bosch Alternator DIY and continuing on my post in that thread, I've finished rebuilding my old Bosch alternator - what an improvement. My swapped engine came with a Valeo 80A which ran 13.6-14.2V at idle. When I installed my rebuilt Bosch it now idles at 14.6-14.8V!
I had originally planned to rebuild my Valeo so I could follow the YouTube DIY:
Valeo - Part I
Valeo - Part II
However, the parts for the Valeo were extremely difficult to source, so I opted for a rebuild of my old Bosch instead.
My alternator (RealOEM):
Brand: Bosch 80A
Production date: 43/96
Bosch part number: 1 740 624
BMW part number: 0 123 315 013
I bought my non-OEM parts from lima-shop.de (German):
1 x Ball Bearing 6304 EHSR 2RS1 c3 - 17x52x17 (14.95 EUR / 19.55 USD)
1 x Ball Bearing 6203 2RS1 c3 - 17x40x12 mm (5,95 EUR / 7.78 USD)
1 x Regulator 14,1V 1197311545 Bosch BMW alternator 545-1980 (42,95 EUR / 56.18 USD)
1 x Slip ring d 16mm for Bosch Alternator (8,95 EUR / 11.70 USD)
1 x Shipping (13,90 EUR / 18.18 USD)
Sub-total: 86.70 EUR / 113.41 USD
Pay-pal fee (3.85%): 3.34 EUR / 4.37 USD
Total: 90,04 EUR / 117.79 USD
No special tools were used, but it was a PITA to remove the bearings. The one on the slip ring can be removed with a bearing removal tool, but the front bearing was inaccessible so I had to resort to proper violence...
"If you find yourself in a hole, the first thing to do is stop digging." - Will Rogers
Old 01-06-2013, 01:46 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Ooooh. An instant classic for the bestlinks!
Old 01-07-2013, 03:13 AM
moots's Avatar
moots moots is offline
wat's dat noise
Mein Auto: '04 525i
woahhh...i was thinking the slip rings are part of the winding ie as 1 unit.....
thanks.great info and pics.....now where's my credit card......
Old 01-07-2013, 09:18 AM
cn90 cn90 is offline
I thought the front bearing is easy to remove, why the "violence"?
Old 01-07-2013, 10:24 AM
Below is a very good DIY on Bosch alternator:
- Rear bearing: gear puller
- Front Bearing: remove the plate holding the bearing, if you have a press tool ---> great, if not use the large gear puller + socket.
http://www.oichan.org/mods/alter/alter2.htm
Some people find that if you gently lift the bearing's seal, apply new grease, then no need to replace the bearing:
http://forum.roadfly.com/threads/130...ternator-issue
Old 01-07-2013, 01:03 PM
pleiades pleiades is offline
Mein Auto: '99 5-spd
You really need shop press to do it on the Bosch units. Although the spindle can be tapped out of the bearing with a small sledge (and something in between to prevent the spindle tip from mushrooming).
BTW..... if you can expose the large bearing well enough to pop a seal off and add grease, I cannot understand why you wouldn't simply just go ahead and replace the bearing outright?
Old 01-07-2013, 02:42 PM
E39 fanboi
cn90, excellent DIY!
Unfortunately I don't have a press, so I had to use a hammer... the bearing was stuck on the spindle, so the casing wouldn't come off. I wasn't afraid to whack it a bit seeing as it was a "spare".
Old 08-15-2013, 10:34 PM
bluebee's Avatar
For the record, this German web page for Bosch alternator parts shows a huge list of cross references for Bosch alternator rebuilding parts such as...
