Sponsored by The Tirerack. Moderated by Rudy@Tirerack.com
Old 01-06-2013, 04:34 PM
RBP3 RBP3 is offline
135 Driver
Mein Auto: 135 Convertible
RFT/Non-RFT compatability
Just bought a 2009 135 w/ sport package and it has OE Run Flats. I plan on replacing them with standard tires, probably Continental DW's. the front tires are 50% warn, with heavily worn outer edges...the rear are relatively new. After I get the alignment straightened out I will need to replace the fronts.
My question is are there any safety or performance concerns if I have Non-RFT's tires on the front and RFT's on the rear? They will both have the same ratings, so I see no issues, but wanted to see if anyone had an opinion or had done this before.
Old 01-07-2013, 06:49 AM
Rudy@Tirerack's Avatar
Rudy@Tirerack Rudy@Tirerack is offline
Moderator
Mein Auto: 1-800-428-8355 X4664
Mixing run flat and non run flat tires should be avoided due to unstable handling, especially at highway speed and in corners.
Tires http://www.tirerack.com/a.jsp?a=AH8&...ires/index.jsp
Refer to 'Rudy/Bimmerfest' as your previous contact when you order online. Credit Bimmerfest.com by CLICKING HERE.
Rudy@Tirerack.com
