Old 01-07-2013, 07:02 AM
C4cat C4cat is offline
Mein Auto: BMW
Hex bolts
Hi everyone, it's my first post. Do you know where I can get some Hex bolts with washers for a z3 hard top support/brackets? The part number is 07119901586. I have contacted some BMW dealers and they said the bolts are no longer supplied or stocked by BMW.
Old 01-07-2013, 07:50 AM
Blacklane Blacklane is offline
Mein Auto: 1998 Z3 Roadster
RealOEM.com usually has the bolt dimensions listed in the supplemental column. It will be something like M8X12-8.8. That's an 8mm bolt, 12 mm long and with a strength grade of 8.8, which is about the middle of the scale.
M8 bolts have a 13mm head.
You can go to any bolt supplier such as McMaster-Carr, Grainger, automotive parts stores, etc. to find the bolts in the style you need. You can use any bolt with a grade of 8.8 or higher.
Old 01-07-2013, 08:52 AM
Mein Auto: BMW
Thank you so much. I appreciate your quick response.
I'm also after the wire for the rear windscreen defrost pictured below. Can you help?
