Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > Z Series > E89 Z4 (2009 - current)
Old 01-07-2013, 09:48 AM
BMWZ4RIDER BMWZ4RIDER is offline
Z4 35i Rider
Mein Auto: 2009 Z4 35i
More Z Projects
Christmas was good to the Z. Many projects were completed.
A. Materials- Roll of 5' x 20 feet of Semi Gloss Black, Flexible, Carbon Fiber Vinyl wrap.
I got a very good quality vinyl from Metro-Styling designed for both interior and exterior. On my Acura, with a lesser quality vinyl, I installed it in the engine compartment and was starting year #5 before selling it and it still looked great and was fully adhered.
This DIY takes cleaning, patience and practice, but is well worth it and the results can be excellent. Also as this is vinyl wrap, it leaves no residue after removal and everything wrapped is reversible.
Jobs:
1. Air Cleaner- CF wrapped around the BMW logo.
2. Air Intake- this was a multi step project but with a hair dryer used to heat the vinyl for shaping, allows compound curves to be installed. Not perfect but looks great.
3. New 68MM BMW Wheel Center caps- I custom cut the CF for covering the BMW Blue. DIY Removal- Si I did not chip the paint, to remove the Wheel Center Caps, I used a window suction cup. Wet the suction cut, press it fully on the center cap and give a quick firm pull and the caps pop right out.
4. BMW Roundels- front, both sides, rear and Steering wheel Roundels. I installed the Black CF over the BMW Blue.
5. CF Lamp Covers- Engine Compartment
5. Lower silver plastic Front Grills- this is my favorite.
B. Ash Grain Wood Dash Kit. I got this kit form CARID. The manufacturer was REMIN. They offered an exact OEM match to the Ash Grain in the Z. I purchased a sample for review before committing. I purchased the basic kit with 27 pieces. See attached schematic. I used 23 of the 27. This kit was designed around the base radio. I have the premium sound system with a different radio/CD player, so from my template, which I made, REMIN is making me a custom 2 price radio/cd kit. Pictures to follow.
This is my 3rd kit. For install DO NOT use the promoter pen suggested for small or curved pieces. It is not needed and it will stain the plastic where used, especially if you wanted to remove the kit or get it on any other surface in the car. This kit and all others that I have used from other companies, use 3M auto body tape to adhere the pieces to the dash and works perfect. This is my 3rd kit and I have never had a piece come loose.
Keys to the Install:
1. Clean, clean and clean again the surface of the plastic where the piece is to be installed with 70% Isopropyl alcohol. This is absolutely critical especially if Armor All or other silicone products have been used on the dash., like I used. I had to go over each section at least 8-10 times with clean alcohol to prep the surface.
Use the blue masking tape to test if the surface is ready. If the tape sticks, the surface is ready.
2. Pre fit the piece to verify fit.
3. KEY- use a hair dryer, heat gun, etc, to heat the piece and especially the 3M tape on the back, as well as warming the dash area for the installation. By heating the 3M tape before install, you have the ability to gently pull the piece off and re locate if needed.
4. For small pieces pull the protective tape off completely and install.
5. For larger pieces- I only pull off 1/4 of the tape so and leave a trailing edge of the red tape to continue after the piece is correctly located. Once the piece is partially installed you can lay the rest of it on the surface and jointly pull the backing tape off and install at the same time.
6. For installation, ,Ever so lightly lay the piece on the dash to verify location. DO NOT put any pressure on the piece, until you are happy with the location, fit and install.
7. After you are happy with the install, use, use a dot, lint free towel and the hair dryer and go over the piece lighting heating and applying pressure.
8. Removal- if you meed to remove the dash kit, again the use the hair dryer, heat the piece and pull from corner.
See attached before and after photos.
C. Real Carbon Fiber Door Sills- Install same as above.
Name:	BMW Aircleaner.jpg
ID:	356442   Click image for larger version
Name:	BMW Air cleaner logo.jpg
ID:	356443   Click image for larger version
Name:	BMW Air Cleaner wrap.jpg
ID:	356444   Click image for larger version
Name:	OEM engine bay.jpg
ID:	356445   Click image for larger version
Name:	CF Air intake.jpg
Name:	CF Air intake installed.jpg
ID:	356447   Click image for larger version
Name:	CF Air cleaner.jpg
ID:	356449   Click image for larger version
Name:	New Center caps OEM.jpg
ID:	356450   Click image for larger version
Name:	New center caps with CF.jpg
ID:	356451   Click image for larger version
Name:	CF Front Center Cap.jpg
Name:	CF Rear Center Wheel cap .jpg
ID:	356453   Click image for larger version
Name:	CF Lamp  caps.jpg
ID:	356454   Click image for larger version
Name:	Center cap removal tool.jpg
ID:	356455   Click image for larger version
Name:	Center cap removal tool 2.jpg
ID:	356456   Click image for larger version
Name:	OEM Front Roundel .jpg
Name:	CF Front Roundel.jpg
ID:	356458   Click image for larger version
Name:	OEM Side Roundel.jpg
ID:	356459   Click image for larger version
Name:	CF Side Roundel.jpg
ID:	356460   Click image for larger version
Name:	CF Rear Roundel.jpg
ID:	356462   Click image for larger version
Name:	F Drivers De badged.jpg
Name:	F Right OEM grill.jpg
ID:	356471   Click image for larger version
Name:	CF F Lower Grills Black upper.jpg
ID:	356472   Click image for larger version
Name:	CF LF Grill.jpg
ID:	356473   Click image for larger version
Name:	CF LF Grill Installed.jpg
ID:	356474   Click image for larger version
Name:	CF F Right Grill.jpg
Name:	CF LF Grill Installed 3.jpg
ID:	356476   Click image for larger version
Name:	Dask Kit 1.jpg
ID:	356477   Click image for larger version
Name:	dask kit 2.jpg
ID:	356478   Click image for larger version
Name:	dash kit pass door.jpg
ID:	356479   Click image for larger version
Name:	Dask kit drivers door.jpg
Name:	CF R F Grill installed.jpg
ID:	356481   Click image for larger version
Name:	dash kit pass vents and door.jpg
ID:	356482   Click image for larger version
Name:	dash kit vents drivers .jpg
ID:	356483   Click image for larger version
Name:	dash kit center vents.jpg
ID:	356484   Click image for larger version
Name:	dash kit steering wheel.jpg
Name:	dash kit pass vents.jpg
ID:	356486   Click image for larger version
Name:	Dash kit console.jpg
ID:	356487   Click image for larger version
Name:	Dash kit vents.jpg
ID:	356488   Click image for larger version
Name:	CF door sills.jpg
ID:	356489   Click image for larger version
Name:	CF drivers door sill installed.jpg
2009 BMW Z4 35i/Space Gray Metallic/7 Speed DCT/Premium,Cold Weather & Premium Sound Packages/Nav/Comfort Access/Ash Grain Interior & Dash Kit/AntiTheft/SportWheel/PDC/WindDeflector/Black Kansas Leather/Smoked Reflectors, Side Markers & 3rd Brake Light/Ferrari Red Brake Calipers/Clear Front Mask/Gloss Black Grill Inserts/6000K LED Lighting/De-Badged/Aluminum Pedal Set/Real Carbon Fiber BMW Door Sills/CF Wrapped Engine Compartment Roundels,F Lower Grills & Center Wheel Caps.
Old 01-07-2013, 01:08 PM
rdkind62's Avatar
rdkind62 rdkind62 is online now
Mein Auto: 2009 BMW Z4
I really like all the work you did and I can imagine it was very time consuming. Carbon fiber was a good choice, but not a fan of the wood grain look on the interior.
BMW Z4, red on black with aluminum trim, Sport Package, Cold Weather Package, Comfort Access, 6 speed manual.
Old 01-08-2013, 01:37 PM
Z4 35i Rider
As I bought the Z used and it was fully loaded, I accepted the Ash Grain. I wanted to convert the interior to Carbon Fiber but there is not good kit to cover the wood without a hack job. I have learned to live with and like the Ash Grain. The new Dash Kit does make a world of differemce and gives the interior a rich feel
HTML code is Off
