Old 01-07-2013, 03:15 PM
malrix malrix is offline
Mein Auto: 2006 BMW 530xi
Unhappy muffled knocking/vibration noise while driving
Hi I've searched all over but can't seem to find the problem I'm having with my 2006 530xi
I hope someone has an idea. Here it goes:
I hear a muffled knocking sound (one per wheel revolution) at any speed that seems to be coming from right front side of the car. With high speed the sounds turns into a constant noise (like very noisy tire). Low speed produces same kind of sound (only a bit quieter), turning left amplifies the sound, turning right makes it almost go away. All that is accompanied by a slight vibration of the steering wheel at highway speeds.
A different set of wheels (tires and wheels) did not cure the problem.
Sound does not disappear while breaking.
Any ideas?
Could it be right axle?
Old 01-07-2013, 04:42 PM
MRV99 MRV99 is offline
Mein Auto: 2011 M3 DCT
I would bet you have something in your tread like a stone or a piece of metal. I had the exact same noise coming from the drivers front. jacked the car and spun the tire to find a rock wedged in the tread and worn flat. Removed the rock, no more noise.
12 X5 50i Sport
11 M3 DCT
11 X5 50i (lemon)
-- SOLD --
08 550i M-Sport
04 BMW 545I sport
07 BMW X5 4.8I sport
02 BMW X5 4.4i sport
01 BMW 540I M/sport
00 SL500
97 SL500
Old 01-07-2013, 05:03 PM
I wish it was that easy. Noise continued even after putting a different set of wheels on it, not just tires.
Old 01-07-2013, 05:42 PM
Gustavoerod's Avatar
Gustavoerod Gustavoerod is offline
Mein Auto: 2006 530i
Wheel bearings?
Old 01-08-2013, 01:31 PM
Dealer says front right wheel bearing is bad. Replacement cost $570. I found a place that would do it for $290.
I'll update if it turns out to be something different.
knocking sound, loud noise while driving, noise, vibration
