E30 (1982 - 1993)
Old 01-07-2013, 04:03 PM
shanto shanto is offline
Mein Auto: 318i
Lateral axle movement .... I think
Hi all,
It's been a while the issue with the bronze e30 that whenever I reach 70-80 Km/h there is a lot of steering movement. It tends to lower as the speed goes higher.
I'm know its mainly the bushing at the wheels but not sure which ones.
Sway bar or control arm or tie rod.
Any suggestions???
Old 01-07-2013, 05:30 PM
downhiller's Avatar
livin large
ball joints or tie rods.
Old 01-08-2013, 05:43 AM
nicholasb nicholasb is offline
Mein Auto: 1987 BMW 325E
Try jacking up the front and see if you can wiggle the wheels by hand. My car had this same problem, needed new tie rods. Hope this is your problem too, tie rods are a lot cheaper (and easier)!
Old 01-08-2013, 06:21 AM
7pilot 7pilot is offline
Git
Mein Auto: 90 Ford Tempo
+1 for both.
m
Old 01-08-2013, 10:31 AM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 2001 540i sport/1994 525i
My car was just doing the same thing around 60-63mph then went away as i went faster.
I just rebuilt my rack (was leaking) new ball joints, tie rods, boots. Alignment Problem solved!
Old 01-08-2013, 11:39 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
Originally Posted by shanto View Post
Hi all,
Any suggestions???
Careful before you start rebuilding the front end.. I replaced my rack and pinion, tie rods and have newer control arms already.. still had a shimmy after the alignment. So I had the wheels balanced.. Ta Dah problem solved. Big problem for these soft rims. They bend easily and unnoticeably. Start with a wheel balancing.. I think it cost me about 30 bucks all together.. much cheaper than the $345 for all I did. (Big discount since I work at a Parts store)
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 01-08-2013, 07:52 PM
Mein Auto: 318i
Trouble shooting plan then:
Wheel balance
Wheel alignment
Tie tod in and out
Ball joints
Steering rack...
Ps: it wasn't this bad till I switched to bigger rims.
Old 01-08-2013, 08:03 PM
downhiller's Avatar
livin large
yea, i would skip the first 2 right off the bat. its not hard to test out the components.
Old 01-08-2013, 09:18 PM
Mein Auto: 318i
Should I be changing both in and outer tie rods at once?
Old 01-09-2013, 10:50 AM
Newman271's Avatar
That Guy
Very rarely will you have to change inside tie rods.. I work at a parts store and the only vehicles I ever sell a whole lot of inner tie rods for are taurus's and dodge's.
1999 540i M-Sport
Silver/Black
1985 335i
R.I.P
#16 of 5,683 made
Old 01-09-2013, 11:06 AM
hornhospital's Avatar
D'oh, You Kids!
I'll have to video the tie rod set I took out of an '87 325e. The outers were pretty bad, but the inners literally rattle in the sockets. You really do need the inner boots on these things!
Edit: never mind. The scrap metal guys got them last month. Forgot about that.
Quotes to live by:
