E30 (1982 - 1993)
Old 01-07-2013, 04:40 PM
DJHayter DJHayter is offline
Mein Auto: 86 325es
differential fluid change ????
i have a 86 325es just wondering how to do it, what fluid to use, and how much. thanks
Old 01-07-2013, 05:28 PM
downhiller's Avatar
livin large
take the lower plug out drain and spray some brake cleaner in to get as much out, then put in 75w-90 oil for an lsd in top plug (after closing bottom) and fill up to the bottom of the upper plug, should be like 2-3 quarts.
Old 01-08-2013, 06:13 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
I used a limited slip additive to mine also.. it was only a few bucks and I figured with these old cars it couldn't hurt.
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 01-08-2013, 10:27 AM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 2001 540i sport/1994 525i
I suggest driving the car around to get the fluid warmed up a bit and then drain it while its still warm so that it flows out better. I never have sprayed brake cleaner in the diff nor will i ever.
Old 01-08-2013, 11:26 AM
Newman271's Avatar
That Guy
Brake cleaner just cleans the gunk out. Would never have any adverse effects on clutches or gears. I use non chlorinated brake cleaner to spray down my flywheel and clutch before I put them in and never ever had a problem (atleast 10 personal cars by now).
But driving will warm the fluid and make the flow a little quicker when you go to drain it.
I used valvoline 75w90 synthetic part number 975, and Kendall limitied slip additive our part number is LSA but that may vary. Pyroil Non Chlorinated Brake cleaner part number NCBPC13.
1999 540i M-Sport
Silver/Black
1985 335i
R.I.P
#16 of 5,683 made
Old 01-08-2013, 01:13 PM
54bobby 54bobby is offline
54bobby
Send a message via Yahoo to 54bobby
Mein Auto: 1986 325es
i believe it's about 1.25 qts
Old 01-08-2013, 02:46 PM
hornhospital's Avatar
D'oh, You Kids!
Fluid capacity depends on engine size due to different differentials being used.
Name:	fluid capacities.JPG
Quotes to live by:
Old 01-08-2013, 05:18 PM
downhiller's Avatar
livin large
youre right. last one i did was my 4runner and it was 2 quarts.
either way, fill till it starts coming out of the upper plug just like half the manual trannies out there.
