6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations. |
bmw 6 series- 22's are rubbing in the back
Can anybody with 22 inch staggered offsets tell me did they have to get any adjustments on there 6 series for the rims not to rub in the back? If so, what was done to get them to stop rubbing?
I have 235 front and 295 back |
I have never had rims that large, but maybe rolling in your fenders might help?
Once a 6'er, always a 6'er. |
what???
Google "rolling fenders". Any decent body shop can do it for $50-$100. They use a device that connects to the hub on one end and has a large rollerskate-like poly wheel on the other which will roll under the lip of the rear wheel well.
Rolling is your only option, other than going for a narrower tire. This is assuming you are hitting the fender, not the shock or spring perch. Look at the rub/wear pattern on the tire to see where it's rubbing. FYI 235 is way too skinny in the front. The car is going to understeer like crazy if you push it in a corner.
Straight lines are for fast cars...turns are for fast drivers '04 M3 - track '06 650i Cab - daily driver '02 Highlander - kid hauler '01 330Ci - winter beater
Any benefit to wheels that big? Seems to me anything over 20 on the e63/4 would be detrimental in a lot of ways (weight, cost, poor ride, fear of pot holes, limited quality tire choice, questionable looks.)
For those with wheels that big, what are the benefits and what tires did you get for those wheels? Reason I'm asking is I'm on the fence between getting a couple of my stock 19 inch wheels refurbished and getting new ones.
![]() 07 650i and 02 330cic |
Thanks, I appreciate that info... I was thinking about changing my fronts to 245-30-22
I have 22`s (22x9 front, 22x10.5 rear) I rarely have rubbing issues, occasionally when bottoming out on dips at high speeds or the angled entry into a shopping center If i have a passenger I get a slight rub but nothing that would warrant any modifications.
As Yorgi stated, getting your fenders rolled may be an option, I will do mine once I lower it. what size tire are you running? I have 255/30/22 front and 295/25/22 in the rear if that helps.
Present: 2011 MB C300: CF Roof and trunk wing, 3M gloss burnt Orange Wrap, 3M carbon fiber 1080p wrap 08 Chrysler 300c stock 09 Audi A4 stock 2008 BMW 550I: M kit, Custom Lexani 20" R-5 wheels, RPI Scoops 2005 BMW 645ci: DINAN Stage 2 software, Magnaflow Custom cat back race exhaust, AFE stage 2 pro dry CAI, GFG custom painted Medellin wheels (22x9 front, 22x10.5 rear) AC SChnitzer dash kit, Matte Mettalic Blue 3m Wrap, Carbon Fiber 1080p 3M wrap custom roundels, Yellow fogs |
i switch from 295-25-22 to 285-25-22 in the rear and problem solved or if you wanna go the cheap way out then getting your fenders rolled is the way to go, but make sure you take it to someone experience bacause they can chip your paint or even buckle your quarter panel
Hi, I'm having same problem, did you ever find a solution?
I have 22s 245/30/22 up front and 295/25/22 rears. The vehicle is lowered with Eibach Sport springs and the solve all for the rubbing issue was to roll the rear fenders. Worked like a charm and havent had any issues since.
Thank you so much!
when i had 22's i had a rub over dips etc... fender roll at local indy solved the problem $80 total
No car is quite like a BMW.... |
I just changed my 22's and did a custom offset, at this point they do not rub at all unlike the occasional rub with the last set. I will now drop it an inch with confidence.
Thank you!
got the same issue with my F13 ..
cant roll rear fenders cos nothing 2 roll in - comes from factory already in !! got 235 in front & 295 rear .. Gona try 285's @ rear & see if it works , will post once done >> |
You could have a specialized machine shop take up to 3mm off the backspacing
| Bookmarks |
| Tags |
| 6 series- 645ci, 650i |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
