Old 01-08-2013, 01:37 AM
essex.stuart essex.stuart is offline
Mein Auto: e39
Whining sorted
Hi on cold start up had a whining from the engine bay sounded like timing belt, also first turn of steering was juddery until the car warmed up. After some time of this getting on my bloody nerves found out i just needed to top up automatic transmission fluid and it was sorted with some relief of no garage bills, thought this might help anyone with same symptons.
Old 01-08-2013, 02:17 AM
Stone Roots's Avatar
Stone Roots Stone Roots is offline
Mugicinal Engineer
Mein Auto: 2003 E39 2009 E60
I'm experiencing a "whining" sound that is similar to what you've described.
Did yours sound similar to the sound in the video located on my thread?
http://www.bimmerfest.com/forums/sho...d.php?t=668670
Old 01-08-2013, 05:08 AM
Fudman's Avatar
Fudman Fudman is offline
Just to clarify, please confirm the source of your problem was insufficient ATF in your power steering reservoir and not in your transmission.
Old 01-08-2013, 08:48 AM
tmvE39/E53/Z32's Avatar
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: Dinan //M5, Dinan 4.8iS,
^My thought exactly, Fudman.
OP, you're topping off ATF fluid in your PS reservoir.
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
FS E39 Hella Celis Euro taillights WITH ballasts, for pre-facelift update.
FS OEM E53 X5 Tow Hitch http://www.bimmerfest.com/forums/sho...49#post9981849
Old 01-08-2013, 01:59 PM
energizedmortal's Avatar
energizedmortal energizedmortal is offline
Mein Auto: 2003 530i
any closed system that needs to be topped off may be leaking somewhere. When I topped off my power steering fluid it turned out all the hoses were leaking and needed replacement.
Old 01-25-2013, 03:47 AM
Mein Auto: e39
Just to clarify it was the power steering resoviour that needed topping up , as one of the clips needed replacing I did This without having to disconnect the pipes , this apparently is a common issue. And yes it sounded similar to the video thought it was the belt or pulleys at first .
