Old 01-08-2013, 08:15 AM
jwrape jwrape is offline
Mein Auto: 96 Z3M (M S52 conversion)
How can I soften my ride but still stay lowered
My 96 Z3 is lowered. The rear end is rediculous. NO movement. Or should I say literally 1/2" of movement. The springs are tooo stiff. I definately rides directly on the ground.
I'm riding on 255/40/17's in the rear.
Could I use a airbag system to get some comfort? Has anyone done this? If not what can I do to soften the ride.
96' Z3 M Conversion. 98' M3 S52 tranplanted into the little beast
Old 01-08-2013, 08:22 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
If you soften it, while staying low, it will bottom out. NOT good.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 01-08-2013, 08:57 AM
Right but currently I have about 3" of travel before tapping the bump stop and it only moves 1/2"
Old 01-08-2013, 10:04 PM
Droptop85 Droptop85 is offline
Mein Auto: 03 Z4 3.0i
The suspension your currently sitting on is?
Old 01-08-2013, 10:05 PM
Check your spring rate. Them swap out your springs for a lower spring rate. I'm running h&r sports. Rides beautiful
Old 01-09-2013, 04:45 AM
I'm not sure. They are Red Springs. The car came with an extra set of rear springs. I am wondering if he was gonna switch them out himself. I'll have to crawl under there and get the numbers off of them
Old 01-09-2013, 04:54 AM
Hmm. H&R race springs ride pretty stiff. And they are red. I would say install the sport springs but those are also red so you may already have them.
Old 01-09-2013, 05:03 AM
I'll have to check and see. Hopefully that's the case and I can just swap them out
