E36 (1991 - 1999)
Old 01-08-2013, 01:39 PM
Ma1 Ma1 is offline
Mein Auto: 1992 bmw 316 ia
Performance chip
Hello guys, can someone help me plz? I need a performance chip for my 1992 bmw e36 316 ia (auto), any recommendation?
Old 01-08-2013, 01:41 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
An auto 316?
Don't bother. Enjoy the fuel mileage and work on handling and braking instead. There are motorcycles with bigger engines.
Sent from my LG Revolution 4G using BimmerApp
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 01-08-2013, 01:43 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Seriously. Do not waste money trying to add power to a 316 auto.
1998 BMW 328is
1966 Pontiac GTO
Old 01-08-2013, 01:48 PM
Ma1 Ma1 is offline
Lolll guys i know, but i thought that can make some extra power in a cheap way, so the only way is to do an engine swap, right?
Old 01-08-2013, 01:55 PM
Ma1 Ma1 is offline
Btw i have another e36 with a tunned 325 engine, the 316 is for daily use only, i am enjoying the low fuel cost
Old 01-08-2013, 02:35 PM
hornhospital's Avatar
D'oh, You Kids!
http://bit.ly/UzaykC
Quotes to live by:
Old 01-10-2013, 01:23 PM
LuckyFlop LuckyFlop is offline
Mein Auto: 1997 328ic
Hahahaha
Old 01-10-2013, 01:24 PM
Well While were on the topic, is the chip a decent option for the 2.8?
Old 01-10-2013, 02:16 PM
Moeman10's Avatar
Moeman10 Moeman10 is online now
hookersandblow
Send a message via AIM to Moeman10
Mein Auto: '99 M3
Sure is. I'd recommend Turner, Conforti, Dinan, or TRM.
Up to you. (I'd also recommend an exhaust to pair with it)
Originally Posted by petriej View Post
You can sleep in your car, but you can't race your house!
Old 01-10-2013, 02:34 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
I think you're looking for a reflash, not a chip.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 01-10-2013, 04:47 PM
Hectorml07's Avatar
Hectorml07 Hectorml07 is offline
WYKDBMR
Mein Auto: BMW E39 6 Speed
Turner is what I have in my car and I'm happy with it. Well that's with the M3 cams working together as well
Old 01-11-2013, 06:05 AM
errr.....reflash? no clue what that is..??
Old 01-11-2013, 06:55 AM
SCJon SCJon is offline
Poet of Signature Quotes
Mein Auto: 1997 BMW 328is
It's having your car's computer reset to a usually different standard.
"It doesn't do any good for me to know more than you if you aren't going to listen to me"
So let it be written, so let it be done.
Old 01-11-2013, 08:25 AM
I Am The Machine
On older cars and the M50 BMWs, the fuel maps and other engine control data are hard coded onto a removable EPROM chip. Simply pop out the chip and put a new one with different parameters and your engine program is different from
Newer OBDII cars don't have these removable chips. Instead you plug a unit into the OBDII port and it will upload the new programming to the DME. This is called a reflash.
Sent from my Galaxy Tab using BimmerApp
// Chad //
You're a derbanana
Old 01-11-2013, 08:29 AM
petriej's Avatar
http://en.wikipedia.org/wiki/Eeprom
The term comes from regular EPROM, which required a flash of UV light to reprogram. The EEPROM does this electronically, but the term stuck.
Your Engine Control Unit has an EEPROM that stores timing information for the car. You can 'reflash' it to get a boost of power with properly programmed timing info.
"Today I Learned..."
GGC BMW CCA #443004
Join the BMW CCA!
Old 01-11-2013, 09:17 AM
I Am The Machine
I always thought EPROM was electronically erasable, I've never even heard of wiping a chip with UV like that.
Interesting....
// Chad //
You're a derbanana
Old 01-11-2013, 10:14 AM
petriej's Avatar
Yea it's pretty awesome. We learned how to do it at Virginia Tech, then the professor let us use EEPROMs, which you just stuck into a special circuit that would do it all really easy. "Gotta learn to crawl before you can walk, bitches!" - Our TA.
Most complex circuits with an EEPROM were designed with the flashing circuitry built in, so the engineers could reprogram the chips without removing them. This is what we have in our cars.
GGC BMW CCA #443004
Join the BMW CCA!
Old 01-11-2013, 11:21 AM
Ill have to look it up to wrap my head around it. thanks for the info.
So what your basically telling me is that the EEprom reflash is just as good as buying a new chip??
Old 01-11-2013, 11:28 AM
petriej's Avatar
I'm saying that the chip in your car is not removable. Buying a new chip is a waste of money. What you really need to buy is a reflash. (Example) Usually they're sold with the equipment you need to hook it up to the connector inside the engine bay that allows you to reprogram your ECU.
You wouldn't buy new rollerblade wheels for your ice skates, would you? If so, I have some awesome ones you can buy...
GGC BMW CCA #443004
Join the BMW CCA!
Old 01-11-2013, 11:50 AM
AHA! its all comming together!
Ill be doing this project this weekend. if I can find the "Shark"
Old 01-12-2013, 10:51 AM
Moeman10's Avatar
hookersandblow
Mein Auto: '99 M3
Man it's definitely been a while. I'm fooling thinking that I can suggest a chip for an OBDII car.
