Old 01-08-2013, 03:35 PM
mikesevel's Avatar
mikesevel mikesevel is offline
Mein Auto: 328i convertible '08
Removing scratches from aluminum trim moldings
I purchased a certified 328i retractable hardtop. I noticed three light scratches on the aluminum trim surrounding the hardtop. I cannot catch a fingernail on them so they are very minimal but they can be seen from a distance. I tried to remove them with 409 cleaner, Meguiar's Ultimate Compound and Quixx scratch remover liquid. No luck! I was thinking of something more aggressive like fine grit sandpaper or grade 0000 steel wool but i am afraid of making it worse than it is. Got any suggestions?
Mikey
New Braunfels, TX
Old 01-08-2013, 03:48 PM
thekurgan's Avatar
Bad Lieutenant
Mein Auto: S62B50 Powered
I would replace the trim.
Ilse
Bruna
2000 M52TU E36/7 Z3 Roadster Schwartz*3 / Rogue RSM / Rogue Trans Mounts / E36M3 FCAB / Beisan VANOS Seals
BMWCCA #453648
Old 01-08-2013, 05:53 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
I am guessing that it is coated in some type of clear coating and that is what is scratched, but getting more agressive with it will most likely go through the coating (like using steel wool) and ruin it. I would start with some wet dry sand paper, 1500 and if that doesn't work, drop down to 1000 or 800, then work your way back up with 1500 then 2000 to get the sandpaper lines out and polish, but be careful, the coating is probably fairly thin.
Just start with the cheapest easiest piece to replace in case you sand through it!
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
