The X5 SAV Forum
Old 01-08-2013, 06:34 PM
wolverine88 wolverine88 is offline
Mein Auto: 2005 BMW X5
Desperately need help on X5/2005
Hi, I need help on my 2005 X5. Its battery was dead last night, so I called AAA to jump start it. After jump start, when I drive it out, I found its instrumental panel is not working, also on the center console, there is no clock or date. FM/CD does work though and show correctly.
On the instrumental panel, there is no light for mileage, trip and the lower center LED window.
Gas and RPM gauge does not work, but the speed, temprature gauge work correctly (I guess).
Any idea? Should I bring it to dealer, I guess it will cost around $$$$ to fix the electornics stuff. I guess I have to fix gas gauge, otherwise, I don't know how much gas left.
Is it possible that fuze just fried? How do I locate them and where to get the replacement part?
Million thanks.
Old 01-09-2013, 08:53 PM
ALTY ALTY is offline
Mein Auto: 2004 530i Sport package
Alternator failure... The system shuts down when village is low... Once you get battery charged up and new alternator the system should come back online....
Sent from my LG-LS840 using Bimmer App
Old 01-10-2013, 08:51 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
The fuse locations are listed in your owners manual...and there should be a card or list in both locations that has an alphabetical list with the fuse location, and a diagram that shows where each fuse is located in the fuse box along with that fuse's amperage rating.
If you take it to the dealer without attempting any trouble shooting on your own...then yes, it is going to cost you $$$. Take a few minutes to look at some of the things you brought up like...blown fuses. BTW, how did AAA jump start your battery? Did they hook up to the jump start posts in the engine bay (which are designed for jump starting the vehicle)...or did they hook up directly to the battery in the spare wheel compartment?
Ditto where ALTY was going in his response...if the battery's voltage is LOW...you will experience a lot of weird electrical gremlins. If the battery was deeply discharged to the point that you required a jump, the battery won't be sufficiently recharged a few minutes after getting the vehicle running...thus lots of electrical gremlins could be present.
As far as the clock & date...can't tell from the way you wrote it...but if the battery was dead...you could have LOST this data. Did you try to re-enter the clock/date info into the MID? If the odometer is still dimmed...the jump may have blown one or more of the FIVE incandescent light bulbs that illuminate the instrument cluster. Again, this is a relatively simple fix even for those that are new to DIY repairs. There's only a couple of screws that secure the cluster to the dash...which can be undone and the cluster tilted out. Once out, the electrical harness can be disconnected...and you can go to your local BMW dealerships parts dept and buy/order the 5 bulbs and replace them. They don't cost that much and are simple to do yourself. If you have the dealership's service dept do it...the minimum will be what ever the labor charge is for at least 1 hour ($140 in some places) just to change 5 bulbs that cost a few dollars each.
five (#2) bulbs + two (#3) screws
click this link to go to the diagram below to retrieve the 11 digit BMW part nbr for the bulbs (#2): http://www.realoem.com/bmw/showparts...74&hg=62&fg=05
Q {BMW CCA Member #191509}
(SOLD)
Old 01-10-2013, 05:31 PM
dryflyguy dryflyguy is offline
Mein Auto: 2006 X5 4.8iS
Sounds to me like your battery or alternator is toast. All the issues you are dealing with is voltage related. I doubt you have any fuses blown.
