Old 01-09-2013, 08:25 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
Mein Auto: 2011 535i M-Sport
Originally Posted by Travel4Surf View Post
Weird... Mine auto releases without this hack, as long as I have my seatbelt on....it disengages the park hold.
Is your car 2012 or 2013? This is for 2010 and 2011 Models, where this isn't the default behaviour.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 01-09-2013, 08:29 PM
Travel4Surf's Avatar
Travel4Surf Travel4Surf is offline
Mein Auto: Everglades 243
2013
Minha patroa é um BMW
Old 01-09-2013, 08:30 PM
JEG23 JEG23 is offline
Mein Auto: 550i
I explained it in my original post, but I guess people keep missing it.
JEG23
2011 550i
Space Gray /Black Nappa, Dark Wood
ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR
Old 01-09-2013, 08:40 PM
Reword the first and second sentence.....we all have ADD and stop reading after the first sentence :!
Old 01-09-2013, 08:44 PM
Mein Auto: 550i
What exactly is hard to understand about
"In MY 2012 and newer cars the parking brake can be automatically released by just pressing the accelerator pedal."
That is THE first sentence.
JEG23
2011 550i
Old 01-09-2013, 09:19 PM
lek lek is offline
Mein Auto: 08 535i, 10 X5d, 13 AH5
I just checked these two codes and it set default as JEG23 mentioned to code for MY13 AH5. I tested it just releases when I hit the gas pedal, but it won't keep the AutoHold on after car stop and restart.
Originally Posted by JEG23 View Post
In MY 2012 and newer cars the parking brake can be automatically released by just pressing the accelerator pedal. This feature was not available in MY 2010-2011 cars. It can be activated by changing the following codes below:
DSC->3000 Allgemein, 20->Funktion_AutomaticDriveawayRelease_aktiv->aktiv (nicht_aktiv is the default)
EMF->3000 Kodierdaten, 14->ADR_AKTIV->ADR_ein (ADR_Aus is the default)
(Note, any errors/or malfunctions will clear up after a complete car shutdown.)
For automatic release, operate the accelerator pedal. The LED and indicator lamp go out.
This is subject to the following requirements:
->Engine on.
->Drive/Reverse position engaged.
->Driver buckled in and doors closed.
This allows me to enjoy even more the Auto-H feature. One thing I did not like is that it engages the parking brake automatically upon shutdown. Now I do not have to worry about remembering to release the eBrake. I just drive away.
As usual, thanks to Shawn for all his help and to Sean (ImSW1) for securing the CAFDs that help me finally find this.
JEG23
Old 01-09-2013, 09:24 PM
Mein Auto: 550i
@lek,
There is no way (yet) to set Auto hold on by default. This code does not do that.
One aspect of Auto Hold is that it sets by default the parking brake on when you shut down the car. That means that you have to remember to disengage the brake when you restart the car. With the "drive away" feature, that is not an issue any longer.
JEG23
2011 550i
Old 01-09-2013, 09:57 PM
heading to south beach...the first 3 rounds are on me
Old 01-10-2013, 11:38 PM
marcosg marcosg is offline
Mein Auto: 2011 BMW F10 528i M Sport
Thank you cn555ic. I have been working on this one for a while, but it was not until Sean provided me with some tools that I was able to get the second code.
JEG23
Thanks JEG23 & Sean for this feature. I have coded it successfully and it works well
Old 01-11-2013, 07:05 AM
Mein Auto: 550i
2011 550i
Old 02-05-2013, 03:14 PM
cn555ic cn555ic is offline
The Coder guy in N.Y
Mein Auto: bmw
Tried to code this into a 2011 535 GT today and there was no
DSC->3000 Allgemein, 20->Funktion_AutomaticDriveawayRelease_aktiv->aktiv (nicht_aktiv is the default) in the DSC module,
I also could not get a green check to go into the FDL of the EMF... There was nothing in green for that module, so I could not even get into it and edit
Very strange
Coding Inquiry call 917-939-4980
Old 02-05-2013, 04:58 PM
Mein Auto: 550i
Very strange
cn555ic,
How old was the I-Step?
JEG23
2011 550i
Old 02-05-2013, 05:14 PM
Mein Auto: bmw
JEG23 I didnt even get a chance to look
Old 02-06-2013, 04:41 AM
Mobileum Mobileum is offline
Mein Auto: 520d f10
My car is a MY2010 EU. Works perfect. Thank you, JEG23.
Old 02-06-2013, 05:43 AM
Mein Auto: 550i
Great!
Thanks for the feedback.
JEG23
2011 550i
Old 03-24-2013, 11:44 AM
berti berti is offline
Mein Auto: F11
Hey, I just want to say thank you for this procedure.
I just coded my F11 2/2011 and now Auto Hold makes sense to be used.
Old 03-24-2013, 03:24 PM
Mein Auto: 550i
Glad it worked for you. Thanks for the feedback.
JEG23
2011 550i
Old 04-02-2013, 04:41 AM
Meister1.0 Meister1.0 is offline
Mein Auto: F07
hey guys from germany,
yesterday i tried to code this funktion on my f07 from dec 2011 :
dsc was no problem.
in the eml there is no caf-file and of course just with the coded dsc the automiatic release does not work.
anyone a good idea how the get it work??
Old 04-07-2013, 08:39 AM
nimuh nimuh is offline
Mein Auto: F10
Very strange
my 2010 F10 does not have the DSC feature that im supposed to change either. the EMF was no problem to edit though... strange? my car has never had a software update so maybe that is the reason. maybe a certain version is needed
Old 04-13-2013, 07:57 PM
For those of you like myself that cannot get this to work, it only works on cars with >= Sep. 2011 Build Date.
- BMWCCA #446923
- flick
Old 04-15-2013, 12:29 AM
I have successfully coded this function in my car and it is a F10 Feb 2011 build.
Old 04-15-2013, 06:22 AM
Interesting.
The FDL Code DCS => Funktion_AutomaticDriveawayRelease_aktiv has the following Paramater:
XPath=boolean(//cat[@val="255"][crit[@val>=1109]]
criteriaVal="1109">SEPTEMBER_2011
Not sure what to make of this...
- BMWCCA #446923
- flick
Old 04-15-2013, 07:29 AM
Nison Nison is online now
Mein Auto: 2011 535i xdrive
my 0910 build works. i think that's the default value from 0911 build.
Old 04-15-2013, 09:57 AM
Well, that is encouraging since you are stateside, and your build is actually one month before mine...but still I don't know why mine won't work....
- BMWCCA #446923
- flick
Old 04-15-2013, 10:26 AM
did you get your software updated?
