The X5 SAV Forum
Old 01-11-2013, 12:36 AM
3202Nick 3202Nick is offline
Mein Auto: 2002 X5
radio fuse
what fuse(s) do I need for the radio in my 2002 X5.. not working ?
Old 01-11-2013, 02:51 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
If you mean the fuse that is located in the electrical harness on the radio itself...it is a 10 amp fuse. For example, I'm referring to the reddish fuse in the pic below on the back side of an in-dash CD43 CD/radio unit...the same applies to the CD53/C43/BM53 units.
If you are referring to a fuse elsewhere...then look for the fuse index in both the front & rear locations which will have the fuses listed alphabetically along with its fuse nbr...also with a fuse box illustration that shows the fuse nbrs place within the fuse box as well as its amperage.
(rear fuses behind right side cargo panel)
Q {BMW CCA Member #191509}
(SOLD)
Old 01-11-2013, 10:19 PM
OzzyX5 OzzyX5 is offline
Mein Auto: 2006 X5 3.0d
Hi Qsilver,
If you open the glove box and look in and up you will see a cover, on the back of the cove should be a lable identifying which fuse is for where and what amperage.
Cheers
Old 01-12-2013, 01:26 PM
QSilver7's Avatar
Originally Posted by OzzyX5 View Post
Hi Qsilver,
Cheers
Since the OP (original poster) only has "Essex" as their location...I'm not sure what part of the world that's in...but kind of sound like it may be the UK. If so, that may mean RHD (right hand drive)...and I haven't been around the e53 world long enough to read/learn how the front fuses are accessed since the steering wheel is in the way. My only perspective as of now, is from the LHD e53s and the page from our owners manual (that is posted in my previous reply).
(SOLD)
