HU_NBT Video from USB
88K views 91 replies 32 participants last post by  siqueiros
#1 ·
from a Buddy on a German Forum I got the following settings for activating Video playing from USB.
HU_NBT 3003 API_USB_VIDEO --> both
this enables the menu selection of "movies" in i-Drive for the USB-Device
if you want to play DivX/Xvid contents as well (or Video-cD at that) the following Settings are also necessary.
HU_NBT 3000 ENT_CODEC_XVID --> aktiv
HU_NBT 3000 ENT_CODEC_XVCD --> aktiv
And it definitly digests almost everything you throw at it.
mpg, avi, mkv, divx .....
even at HD Resolution (I tried a cut from a BluRay in 1920*1080p/24) it works perfectly.
Only drawback (so far)
You dont get into the menu for "zoom" (which might be solved by putting that function on a favourite) and the selection of audio-tracks (maybe same recipe will do the trick).
Might be very useful for all you with VIM activated......
Razorback
#3 ·
Razorback
Thanks, i will try.
is inside CMB_MEDIA , isn´t it?
#8 · (Edited)
In this situation it's more than just software. HU_NBT is associated with the new iDrive system which incorporates the combox et al. into the actual unit mounted behind your stereo controls rather than in the trunk. If you have the new iDrive you will have an HU_NBT rather than a HU_CIC ecu.
OP, great post for additional video options. Just another reason I wish there was a cheap avenue for retrofit.
Sean
#11 ·
got a bit of a problem - my car is German Language setup - but lets give it a try:
In the MEDIA menu you select EXTERNAL MEDIA (USB)
there you will see a menu "more media"
and there you can choose
Audio books, Audio Podcasts, and VIDEO
if you choose VIDEO you will see a list of directories/files with video content the unit can play.
Razorback
#31 · (Edited)
I have HU_CIC but not HU_NBT, which you kindly explained via PM that only 2013 F10 and F30 2014 have.
Without HU_NBT, how do I achieve what the OP achieved?
From what I gathered from this thread, 4 settings need be changed/ coded:
***8226; Allow Video Files to be saved to HDD and played from USB + additional CODECs
HU_NBT > 3003 > API_USB_VIDEO > both
HU_NBT > 3000 > ENT_CODEC_XVID > aktiv
HU_NBT > 3000 > ENT_CODEC_VCD > aktiv
HU_NBT > 3000 > ENT_MC_VIDEO_SUPPORT > aktiv (this is import videos to the HDD)
#32 ·
Yes, and also that USB Video is not possible over 6FL USB Port with CIC.
#34 ·
Yes. You can retrofit NBT, but after buying the Head Unit, replacing all the FSC Codes, making the Custom Wiring Harness, and installing and coding it, it will be over $5k. Plus, when you go in for dealer programming, you will need to swap it back out for the old CIC unit as ISTA/P will reject it on your build. So, it really isn't practical.
You can though replace the 6FL Aux-In USB port with the AV-In USB Port from the Mini Cooper, and run a FBAS Video line from it to the back of the CIC, probably for around $250.
#43 ·
Set the value to FF in
SPEEDLOCK_X_KMH_MAX
SPEEDLOCK_X_KMH_MIN
Unrelated question.
Could you please post a picture of your car from the front or at an angle with the headlights on, preferably at night? Would like to double-check something.
I cannot set the parametr to FF editing the first field I only have nicht_aktiv, 8km_h and 3km_h
