E34 (1989 - 1995)
Old 01-07-2013, 07:16 AM
hh3uunp's Avatar
hh3uunp hh3uunp is offline
Ball Don't lie
Mein Auto: 2001 Dinan m5
Won't start not battery chainsaw sound
So since my e39 been out of commission due to the poor roads in Springfield. I have been driving my brothers e34 but this morning it wouldn't start and it wasn't the battery. My mechanic skills end there. Sounds like an idling chainsaw
If first you don't succeed you must try again, and then again
Mods
Dinan S1, Drilled slotted rotors, Akembo Pads, 19 in MPars,Zoinsville Super duty kit,
Resident Grammar and Spelling expert
Old 01-07-2013, 10:44 AM
paperplane94 paperplane94 is offline
Mein Auto: 1989 525i M20B25
If you hear the starter turning but the engine is not turning then the solenoid on the starter has failed. You can try to strike it with something to get it to engage, but replacement is best.
Old 01-07-2013, 10:58 AM
"chainsaw sound" tells me that the starter is turning, but not the engine.
Old 01-07-2013, 11:04 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Originally Posted by Monsignor View Post
It could be the battery not giving enough power. These cars tend to really need lots-a juice.
A car needs four things to run
Air
Spark
Fuel
Compression
Make sure the fuel pump is running and check the FP relay; it seems to be a commmon issue on these bad boys.
From there try a battery.
Fixed.
Most problems are usually something simple !
Originally Posted by noego View Post
It's Deja Poo - as in, I've heard this **** before.
Steve
Calypso Red 1992 525i with 225K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-07-2013, 11:22 AM
CarDriver's Avatar
CarDriver CarDriver is offline
Mein Auto: 1992 525it /2004 ML350
Good answer
Time to replace the starter motor. When the pinion gear does not come out far enough to proporly engage the flywheel, it makes that awefull sound. That is the sound of the gear grinding on the fly wheel.
Old 01-07-2013, 12:12 PM
hh3uunp's Avatar
Ball Don't lie
OP, does the engine crank and not fire?
The engine doesn't fire
Update
1. Checked all the fuses/relays
I don't really have a lot of time to mess with it
Mods
Old 01-07-2013, 01:35 PM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
The bendix gear on your starter may have some broken teeth or worse case your flywheel has a bad spot ...
Sent from my Desire HD using Bimmer App
Old 01-07-2013, 01:53 PM
BMR_LVR's Avatar
Humble E34 lover
using that logic
  • oil
  • coolant
  • radiator
  • fan
  • transmission
  • driveline
  • differential
  • wheels
  • tires
  • brakes
  • seat
  • steering wheel
  • pedal assembly
  • brake fluid
I'm just messing around. I know what you mean. At high mileage which is common for a car that can possibly be registered a classic used daily, cylinder wear can cause compression issues.
I dont think OP has suddenly woken up and found his car is pushing 0 psi on all 6 (8?) cylinders though...
I wasn't saying that compression was his problem, but it is one of the 4 basic tennants of a gasoline internal combustion engine. Honestly, I was just messing with you a little just for fun. Guess I should have used an emoticon like or
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-08-2013, 03:53 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
just to confirm, we are talking about the E34 not the E39 right?
E30 above Sold
Last updated 2nd January 2014
Old 01-08-2013, 04:46 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
Yes. His brothers E34 because his E39 is OOC
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 01-08-2013, 04:52 PM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
It still is not clear if the starter is turning over the engine, and the engine isn't starting OR the starter is not engaging the flywheel and the engine isn't turning over as the key is turned.
Two very distinct problems, two different solutions
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 01-08-2013, 05:02 PM
hh3uunp's Avatar
Ball Don't lie
I have no clue. It was towed to my Indy for repairs mainly I just don't have time to fix it.
Ill update once I get it back so you guys can know what was wrong
Mods
Old 01-08-2013, 05:43 PM
Radian's Avatar
Radian Radian is offline
Mein Auto: '91 535i 5-spd
Originally Posted by supertech777 View Post
the bendix gear on your starter may have some broken teeth or worse case your flywheel has a bad spot ..
+1
Good food, good people, good times.
Old 01-08-2013, 11:00 PM
BMWFatherFigure's Avatar
Old School
If the fly wheel has a bad spot turn the motor in normal direction about 30degrees. Might even start and get you to repair shop.
Current:
E38 Parts Car
Previous:
Old 01-09-2013, 06:49 AM
Monsignor's Avatar
Mein Auto: Sig
Can you explain why turning the motor 30 Degrees would change how the starter engages the flywheel any differently?
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-09-2013, 06:51 AM
BMR_LVR's Avatar
Humble E34 lover
I see that BMWFF is off line, so I will venture an answer if he doesn't mind. If there is a bad spot in the flywheel, and the starter gear cannot engage it where it is, then by rotating the crankshaft, it may get to where the teeth on the flywheel are good therby allowing the starter gear to engage and spin the flywheel enough to get the car to crank.
Correct me if I'm wrong FF.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-09-2013, 07:25 AM
Monsignor's Avatar
Mein Auto: Sig
But wouldnt it just get back to the bad part of the flywheel eventually if it doesnt fire immediately. How many turns does a motor go through before firing usually? I strongly believe it would be at least 1 full rotation.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-09-2013, 07:36 AM
BMR_LVR's Avatar
Humble E34 lover
Yeah, but ideally, the flywheel would have enough rotational inertia to allow the bad spot to go past the starter gear. Not perfect by any means, but perhaps it would allow him to get it started so that he can get it to the mechanic.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-09-2013, 08:08 AM
Monsignor's Avatar
Mein Auto: Sig
I would love OP to try this and to post results.
Obviously the flywheel has to be the issue in this case. And the issue in the flywheel has to be a single bad spot in the teeth so chances are slim this is even the problem. Turning the engine a touch is free and harmless. Infinitely worth a shot.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-09-2013, 08:17 AM
BMR_LVR's Avatar
Humble E34 lover
Originally Posted by hh3uunp View Post
.... It was towed to my Indy for repairs mainly I just don't have time to fix it. .....
He already towed it to his mechanic
Joe: 1
Steve: 1
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-09-2013, 08:31 AM
hh3uunp's Avatar
Ball Don't lie
Joe: 1
Steve: 1
Yeah now we play the waiting game. Tick tock tick tock ... This is taking too long
Mods
Old 01-09-2013, 08:32 AM
Monsignor's Avatar
Mein Auto: Sig
That was a quick turnaround...
Kudos, touché, so on and so forth
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
