1988 BMW 325I issue. - Bimmerfest - BMW Forums
E30 (1982 - 1993)
Old 12-16-2012, 03:28 PM
Wolfy Wolfy is offline
Mein Auto: 1988 BMW 325i
Lightbulb 1988 BMW 325I issue.
I have a 1988 BMW 325i convertible and heres the problem
Today as I was driving I noticed the head unit turned off it went from playing music to just a blank screen so as I come to a stop I turn the car off since it felt like it wasn't up to tune both music and driving wise.
So as I go to turn the car back on it dosen't want to well start you hear it turn over but no kick back into starting.
I looked at the fuses and a 7.5 fuse had blown, so I place a different fuse into it and then my friend jumped my car, as the car turns on its running for a couple minutes then makes a sound like its dying or kicking off and everything shuts off first the head unit then the whole car.
Now I'm in need of advice on what to do next the car is only allowed one more day to stay where it is at then Im screwed could it be the Alternator or the starter? Or would it be the battery however, the battery is pretty much new I got sometime during the end of the summer.
Any help would be appreciated.
Old 12-16-2012, 05:11 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Sounds like your alternator is kaput. Jump it off, then with it running check voltage across the battery terminals. Should be 13.8 or more. If it's less then the alternator is gone. If it is putting out charging voltage the battery has at least one dead cell.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 12-16-2012, 05:18 PM
downhiller's Avatar
livin large
between 14.5 and 13.8. it could be overcharging. or you have a short somewhere.
Old 12-17-2012, 05:15 AM
Hmm, I will try that now I'm wondering if the 7.5 fuse that blown had anything to do with the car not wanting to start.
Also could it be my spark plugs going bad as well? I purchased new plugs a little bit ago and havent installed them yet.
The car when I put the keys in the ignition and turn over without starting the lights light up and everything seems to work yet when I go to turn it over it dosen't want to follow through a 100 percent.
And I only have today to fix the issue or have it towed.
FML.
Old 12-17-2012, 05:48 PM
downhiller's Avatar
livin large
depends on what that 7.5 fuse goes to. have a number location
Old 12-18-2012, 06:17 AM
I think number 21
Old 12-18-2012, 02:06 PM
Microtesties Microtesties is offline
Unregistered User
Mein Auto: 1990 BMW 525i
If it is your alternator you may want to check your voltage regulator first before replacing the whole thing. If the brushes are too short the alternator won't create any current, this is what happened to me, Bently says the minimum brush protrusion is 5mm (1/4") and one of mine was 1/8". Soldered in a new set of brushes and your alternator is back to its glory of only a few bucks, I paid $6.44!
Year: 1990
Model: 525i
Transmission: 5 speed
Mileage: 250k
Old 01-15-2013, 03:20 AM
ozosil ozosil is offline
Mein Auto: 323i
YES, check you voltage regulator, screws right out and costs like a few bucks to fix, I bet that is the problem.
