Outside temp gauge question
Hey board
Outside temp gauge reads constant -40. Not quite that cold! How do I check and fix problem E39 1997 528i Dave PS can I reset service indicator light from inside car? Thx! ![]() Sent from my SAMSUNG-SGH-I777 using Bimmer App
Bimmer Dave ![]() Remember Boys, once you've grown-up, Santa delivers his joy year-round... on a flatbed! 1994 E34/530i manual, Oxford Green Metallic on Tan - totaled (not my fault... honest! )1997 E39/528i manual, Arctic Silver Metallic on Black |
Check that the temperature probe is still there and is plugged in.. the proper mounting location is a small notch with a clip under the front bumper near the passenger's fog lamp. (It's on the underbelly of the bumper.)
2000 528i M-Sport 5speed Last edited by DPP528; 01-09-2013 at 02:24 PM. |
Service indicator light must be reset at the 20-pin connector under the hood, on the right side fender well.
Your choice: short two pins together, or buy the Peake code reader. Search here for details.
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. |
If you decide to use a wire or needle nosed pliers instead of buying the dedicated tool...DO NOT short just ANY 2 pins in the DLC connector. You have to short 2 specific pins...and do it following specific instructions. You short pins #7 & #19...look closely and you'll see that the pins are numbered. Again, make sure you have the CORRECT pins...if not, you can turn something as simple as screwing in a light bulb...into a horrible frustrating electrical nightmare trying to figure out what you did wrong.
INSTRUCTIONAL PROCEDURE Click the following link and scroll down past the instructions on how to change the oil...and you'll see the instructions on how to reset the SI lights: Hint: consider marking the pins with paint or fingernail polish so that pins #7 & #19 are easily identifiable...this will help with always selecting the correct pins as you grow older and your eye-sight isn't as good as it used to be.. ![]()
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) Last edited by QSilver7; 01-09-2013 at 10:17 PM. |
Your ambient temp sensor is done. I replaced mine and relocated it to avoid ripping it off again.
![]() 01 Anthracite 525i Sport, with 01 E53 3.0 and 91 Z32TT |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
