Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series > 6 Series DIY
6 Series DIY
6 Series Do It Yourself (DIY) forum.
Old 05-09-2013, 09:34 PM
ghas24 ghas24 is offline
Mein Auto: bmw 50i
22's on 07 650i wont fit
hey guys i just bought 22's with 255/30zr22 front and 295/25zr22 rear. the rear ones fit perfect but the front ones fit but the top of the tire scrapes with the spring. what should i do? do i have wrong tire size on the front or do i need to spacers ?
thanks for your help
Old 05-12-2013, 03:34 PM
Trompa401 Trompa401 is offline
Mein Auto: 2005 bmw 645ci
I have 22"s on my 645ci and i cant tell im not ridin stock you need a good wheel spot to hook that up my right side rubbed a bit until we notice the suspension was turned thr wrong way ...i have bilstien adjustable suspension tho my tire and wheel stats are
- 22x9 front
- 22x10.5 rear
Carbon Series Tires 255/30/22 - front 295/25/22 - rear
Old 05-13-2013, 02:26 AM
Old 06-10-2013, 06:16 PM
BrooklynsFinest BrooklynsFinest is offline
Mein Auto: BMW 645ci
I know this is late but depending on your offset 255"s will not fit, the tire will rub on the bottom spring plate...235's should fit perfectly.
Present:
2011 MB C300: CF Roof and trunk wing, 3M matte aluminum grey/matte black USAF theme wrap.
08 Chrysler 300c stock
2005 BMW 645ci: DINAN Stage 2 software, Magnaflow Custom cat back race exhaust, AFE stage 2 pro dry CAI, GFG custom painted/CF Hydro dipped Medellin wheels (22x9 front, 22x10.5 rear) AC SChnitzer dash kit, Matte Aluminum Red with Carbon Fiber BMW performace stripe wrap, custom roundels, Yellow fogs, custom painted brake duct rings.
Old 06-15-2013, 09:28 PM
March1916's Avatar
March1916 March1916 is offline
Mein Auto: 2016 750i xDrive (G11)
Sould have got 21's. 22's are too big.
2016 750i xDrive (G12) :: Alpine White | Black Nappa Leather | M-Sport with 20" M Light alloy wheels | Driver Assistance Plus & Plus II Pkg | Executive Package 2 (Power side window shades - Front ventilated seats - Instrument panel with leather - Front massaging seats) | Display Key | Ambient Air Package | Bowers & Wilkins sound system | Stainless Steel Pedals
Old 06-22-2013, 11:43 AM
gbelton's Avatar
gbelton gbelton is offline
///M for Motor Sports!
Mein Auto: No More 6 Series
22" Wowsers!
The Tail of The DRAGON, YES!!
2008 Alpine White, Portland Brown ///M5 (SMG)
2008 Alpine White, Fox Red ///M3 (6MT)
2008 Sapphire Black, Black 750Li
Old 06-22-2013, 12:04 PM
andrewkpt andrewkpt is offline
Infamous06
Mein Auto: 2006 bmw x3 3.0i
22s on any bmw is a dumb idea.... go buy a chevy and try that hahahaha
Black
Mans
Whip
Old 06-22-2013, 06:08 PM
Yorgi's Avatar
Yorgi Yorgi is offline
255/30-22 is too big - 4.9% larger outer diameter compared to stock. You are supposed to stay within 3% max of the stock diameter.
A small spacer, say 10mm, may help since the spring perch has more clearance as you move away from the strut.
You can't really compare your setup to Trompa401 since he is running coilovers with a completely different spring/shock setup compared to stock.
What size are your wheels (width). A 235/30-22 is 3.1% larger than stock and should fit if the wheel is not too wide for 235s. Rears should be 285/25-22 to match the diameter of the 235/30-22 fronts.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
