E34 (1989 - 1995)
Old 01-09-2013, 09:37 AM
zfxpE34 zfxpE34 is offline
Mein Auto: 1995 BMW 540i E34
Hello, new owner of E34
Hello, I am in the process of purchasing a 1995 540i..
Now the bad.
It has had the oil pan replaced because the previous owner cracked it.
I have the carfax's on the vehicle, no accidents just the cracked oil pan.
It has since been replaced, obvious (now i'm just repeating myself), this is my first BMW, "oil pressure check" is showing up on the self diagnostic, could this just be the plug, or a lot more serious?
Is it still worth 3500?
the car is MINT.
Old 01-09-2013, 09:45 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: M50 Big Body
Carfax is a load of crap. Tons of mechanics wont even submit that stuff.
Sent from my SAMSUNG-SGH-I747 using Bimmer App
1995 525iA 250k mi Shifted Performance E34
2006 325i/6 48k mi
2003 350Z 87k mi Shifted Performance 350Z
Garden State Euros
Old 01-09-2013, 10:02 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
The M60 engine (530 and 540) have known problems with the oil pump bolts coming loose. It is possible that this happened and that is what cracked the previous oil pan. Did the prior owner tell you how he cracked it? Also, there is no real way to know how much oil may have leaked out before the prior owner realized that there was a problem
I HIGHLY recommend a PPI (pre-purchase inspection) by a reputable BMW mechanic. It will likely cost $75-$100, but would be money very well spent in this particular situation.
I would make sure that the mechanic measures the actual oil pressure to ensure that the oil pump is not bad. Ideally, the mechanic would have tightened up/replaced any loose oil pump bolts when the oil pan was replaced.
As Elmer Fudd would say .... Be vewy wewwy ....
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-09-2013, 10:16 AM
Microtesties Microtesties is offline
Unregistered User
Mein Auto: 1990 BMW 525i
Agreed, a pre-purcahase inspection is definitely in order. Lubrication is one of the most important parts of an engine, not something to be overlooked. My BMW owners manual states that if the low oil pressure light comes on at any time the car should be turned off as quickly as possible and be towed to a shop.
Year: 1990
Model: 525i
Transmission: 5 speed
Mileage: 250k
Old 01-09-2013, 10:18 AM
I asked the same question, he stated clearly the error came after the oil pan, The oil pan was cracked by going over one of the pump stations at a gas station (where they refill the gas tanks). and I believe it is in need of oil as it sat for about a year.
The car runs GREAT, it does idle SLIGHTLY rough, does not spit nor stutter.
Old 01-09-2013, 10:31 AM
BMR_LVR's Avatar
Humble E34 lover
My recommendation still stands. You need to know what the actual oil pressure is. Also, I would see if you can get the name/number of the mechanic that replaced the oil pan to see if he addressed the oil pump bolts.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-09-2013, 10:37 AM
Monsignor's Avatar
is the car lowered? how would driving over one of those gas things crack a pan? my Pan is 3.5" from the ground and it's never scraped any of that. A cracked pan driving through a gas station points to some drive-it-like-you-stole-it behaviors = no bueno.
I would take this car with a grain of salt... in theory. In reality, it's a 540i so i'd make whatever excuses i wanted and have that sumbitch in my garage ASAP.
But do as i say not as i do and so on and so forth...
2006 325i/6 48k mi
Garden State Euros
Old 01-09-2013, 11:10 AM
here in florida they're raised high and make your car bounce, but I want it.
I think personally it's worth it..
If it's the oil pump bolts I can inspect this.
I'll change the oil three times, and see where that leads me.
Old 01-09-2013, 11:14 AM
BMR_LVR's Avatar
Humble E34 lover
Originally Posted by zfxpE34 View Post
..... If it's the oil pump bolts I can inspect this....
Unless I am mistaken, you will have to remove the oil pan to do this.
Good luck with it and ..... pics are mandatory
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-09-2013, 11:17 AM
Monsignor's Avatar
You will have to remove the oil pan to do this.
This is true.
Also, even if you're pulling pans and pumps, still have a mech take a manual pressure test.
2006 325i/6 48k mi
Garden State Euros
Old 01-09-2013, 11:24 AM
Both of you guys are absolutely amazing.
I have never joined a forum and had so much support. I'll post pics tonight!
But i'm aware it'll be a second car to be honest with you, so i'll take whatever time is required.
Old 01-09-2013, 11:26 AM
BMR_LVR's Avatar
Humble E34 lover
Sounds like you already pulled the trigger
Looking forward to the pics.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-09-2013, 11:36 AM
Monsignor's Avatar
+1
Cant wait to get this one road worthy with you. i <3 540s soooo much.
Some day i'll have my Hellrot 540i/6
2006 325i/6 48k mi
Garden State Euros
Old 01-09-2013, 02:04 PM
, and yeah I pulled the trigger, took (drove) it to Ferman, had it tested, came out to be just needed a reset because the stock radio is missing and it wouldn't allow it to reset, the only thing wrong with it is that it needs new spark plugs!
Old 01-09-2013, 02:13 PM
Monsignor's Avatar
you win.
2006 325i/6 48k mi
Garden State Euros
Old 01-09-2013, 02:21 PM
I should just go ahead and do spark plugs and coil packs right?
Old 01-09-2013, 02:23 PM
Monsignor's Avatar
are those confirmed bad? if they are, then yes.
2006 325i/6 48k mi
Garden State Euros
Old 01-09-2013, 02:25 PM
No, not confirmed but at 108k shouldn't I do it?
or for now should I go on that "if it ain't broke don't fix it" method?
Old 01-09-2013, 02:27 PM
Monsignor's Avatar
aint broke dont fix it.
does she come with service records? anyway to know when and what was maintained last?
2006 325i/6 48k mi
Garden State Euros
Old 01-09-2013, 02:30 PM
No.
Not that I was given or shown.
Old 01-09-2013, 02:34 PM
Monsignor's Avatar
oh well. we're wingin it. If it runs fine, no smoke, no smell, no rough anything, leave it be. when* that stuff happens we'll tackle it.
*as in not "if".
2006 325i/6 48k mi
Garden State Euros
Old 01-09-2013, 02:47 PM
Like I said "slight" rough idle
Old 01-09-2013, 03:52 PM
Monsignor's Avatar
Inspect the plugs if they're not good then change them. Rough idol isn't too big of a deal.
2006 325i/6 48k mi
Garden State Euros
Old 01-09-2013, 04:30 PM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 2000, 1995 540iA, 07 525
That looks a lot like my car! It originally came from Florida too. It's in great shape as yours is. Enjoy!
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
Old 01-10-2013, 06:17 AM
I drove her today for quite some time..
THE POWER.
