E34 (1989 - 1995)
Old 01-09-2013, 08:20 PM
oilslick oilslick is offline
Mein Auto: 325is
Question E34 brake light
The brake light warning comes on when the brakes applied the first time. I have changed the bulb twice with BMW OEM bulbs, but the light continues. Will the reset tool extinguish or do I need to discharge the computer as illustrated in the video?
Old 01-09-2013, 08:23 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
There is a small switch at the bottom of the brake pedal that needs to be replaved
Sent from Joe's Galaxy Tab 2 via BimmerApp
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 01-10-2013, 12:06 AM
Mein Auto: 1989 525i M20B25
http://www.bmwe34.net/E34main/Mainte...ake_switch.htm
Old 01-10-2013, 02:48 AM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
oriellys auto parts 12 bucks !
Sent from my Desire HD using Bimmer App
Old 01-10-2013, 07:14 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
You say that you changed the bulb twice. Do you actually have a bulb out? Does the warning say "Brake Light Circuit" or "Brake Light"? If it says "Brake Light", then you have either a bad bulb or a bad wire. Don't forget to check the third brake light at the back glass. If it says "Brake Light Circuit", then you have to replace the brake light switch as advised above.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-10-2013, 07:20 AM
Monsignor's Avatar
Mein Auto: Sig
This is true. OP does say that it comes on when the pedal is pressed which is a bulb out. Could be a fuse or bad wire...
Sent from Joe's Gakaxy SIII via BimmerApp
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
