Old 11-23-2013, 09:29 PM
Brendan K Brendan K is offline
Mein Auto: Mazda 6
Moisture in Headlamp
Hey BMW owners, I am sure some of you have had this problem before. I am getting moisture in one of my headlamps. Does this mean there is a void or fracture of some sort in the headlight or does the moisture need a way to escape?
Old 11-23-2013, 11:18 PM
lgr122 lgr122 is offline
Mein Auto: '00 e46 M43, '05 e87 M47
Those headlight have small ventilation in back, so those lights should be able to "cook" small amount of moisture out of there, but it would be good, if more doesn't get in too easily.
Old 11-24-2013, 10:41 AM
Starless Starless is offline
Mein Auto: 2002 325i Auto
The good thing about E46 headlight assembly is that it can be taken apart. When you do you'll notice there is a rubber gasket between the lense and housing. Changing that gasket will help the problem.
Old 11-27-2013, 11:12 AM
Mein Auto: Mazda 6
Thank you for the advice on the headlamp Alex. So how can I go about finding a gasket for the housing of the headlamp for this issue? Such an odd part must be a hard find and I hope they don't require to order a whole headlamp.
Old 11-27-2013, 01:09 PM
moiz21's Avatar
moiz21 moiz21 is offline
Mein Auto: '99 323i 5-Spd
Not that hard to find. Use realoem.com when looking for part numbers. Here you go: 63128380210
MODS
P46 Projectors + FX-R Retrofit + 6k D2S/ 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
Old 11-27-2013, 11:46 PM
JayKayo's Avatar
JayKayo JayKayo is offline
The UltimatE46 Enthusiast
Mein Auto: 2005 330Ci ZHP
I've had the same issue just last month.
To be honest, if you can just find the hole where the moisture is getting in, you can seal it up using some stuff you can find laying around your place. If the hole's small enough, even super glue could work - assuming it's not anywhere where it comes into contact with other things.
I just happened to have some extra sealant around my headlights from the last time it was baked and opened up. Left the hood up and the car facing the sun for a bit. After it dried, tore off a piece of the silicone and plugged up the hole.
It rained for a few days after but no more moisture.
headlamp moisture, moisture in headlamp
