Old 01-10-2013, 03:19 PM
frankjr8 frankjr8 is offline
Mein Auto: 2008 X3 Wife, 2009 528xi
09 528XI Service Requirements
I just bought a used 528XI and in idrive, under service requirements is shows Vehicle check in 7k miles, what does this mean?
I have searched but cant find when the maint. is stated due as in at certian incraments.
Also what is checked or changed.
Any help would be appreciated.
Old 01-11-2013, 08:32 AM
Hey guy I guess I am looking for a current/correct maint schedule. So I can maintain this car and not involve the dealership.
I found this
http://www.bimmerzone.com/category/T...nspection.html
Is there a better current schedule out there?
Old 01-11-2013, 12:15 PM
wcr3d wcr3d is offline
Mein Auto: 2013 535iX M Sport
You could just let Idrive tell you when and what maintenance then reset as you complete.
Here is something that will help with everything else...
Level I/II Inspection
this is what should be done at the vehicle check interval.
Old 01-11-2013, 01:45 PM
Is that the one you follow?, i have read plugs are good till 100k
Will the car ask for INSP 1, or INSP2?
curious
Thanks for the help
Frank
Old 01-11-2013, 02:33 PM
I haven't had mine very long, but I have learned a lot in a short time. I had a couple oil leaks and had mine in the shop. Valve cover and transmission sleeve (known problem with N52 AT "Automatic Transmission"). While in there it was given the level II. They call it something else now, can't recall what that is at the moment. The car won't tell you Level I or II, it will just say Vehicle Check. My suggestion would be to do as much reading now as you can, then you can make a better decision as to what level and frequency you feel good about. About the plugs, That will vary a lot, if you you can find what the recommendations and current countdowns are. The plugs are part of that. I think its under "Information Sources, Vehicle Information". Anyway its a good idea to sit down and surf Idrive to get more familiar with all the information it holds.
Old 01-11-2013, 07:33 PM
Ok great!
Thanks for the help.
Frank
