E36 (1991 - 1999)
Old 01-26-2013, 05:39 PM
byebiturbo byebiturbo is offline
Mein Auto: 98 328is
Valve Cover Blew Up
Hey everyone, new to the forums here. I come from a VW/Audi background and I must say, I am LOVING the BMW scene so far.
I picked up a 98 328is where the previous owner claims he did a money shift into 2nd getting off the highway. From what he told me, the car started misfiring and lost most of its power, so he shut it off, got it towed and put it up for sale.
I got the car towed home, where I thought I'd crank it and see exactly what was going on... bad idea lol. It cranked for less than 2 seconds before an extremely loud pop happened, blowing the valve cover into pieces over my neighbour's lawn:
So far from my research, I have found that this can happen from a frozen PCV. However, upon removing the valve cover and pulling the spark plugs, I found this:
Cylinders 1-6 (from right to left)
I also did a compression test and found 110-130psi on the first 5, but no compression whatsoever on number 6.
I don't mind getting another motor and swapping it in, but does anyone have any idea what could possibly be going on? I'd rather just swap a head over if that is all I need, as I initially thought he just bent some valves until I pulled that last plug...
Thanks in advance!
Old 01-26-2013, 05:46 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
ummm.....if the plug on the far left is #1, then i would expect to not see much (if any) compression in the #1 cylinder....
#6 is closest to the firewall.
the first hint is 'money shift'. this does *terrible* things to the motor.
i'd plan on a motor, as the plug that is all damaged could only have been damaged by the parts in the cylinder, which would be valves and piston.
in order to have the piston contact the plug, the con rod would have to be all but swinging in the breeze, which is not exactly what i would expect from a money shift. i would more likely say that the valvetrain took a severe hit, lost a valve or two (but no more than 4.... ) and that was boucing around inside the cylinder.
if that is the case, then the cylinder wall is scored, the piston is toast, as well as the head.
so, yeah....looks like a motor.
df
Old 01-26-2013, 05:51 PM
Mein Auto: 98 328is
The far left is #6, I ordered them wrong in the picture lol my bad. :P
The thing is that the piston doesn't look damaged at all... and it moves up and down at the same rate that the others do when cranking it. :S
Old 01-26-2013, 06:04 PM
how'd you see the piston without a boroscope?? that's a tiny, difficult to access hole to inspect the entire piston face...
and the cams cover the valvetrain, and the lifters the valves themselves, so until the cams are removed, the only way to even come close to checking if the valve dropped is to get the cams on the #6 cylinder to the valve fully cosed position and see ifthere is a gap between the lifter and the cam. see if it wiggles around. (it shouldn't)
or, pull the cams.....
either way, you are going to find nasty stuff in there.....
df
Old 01-26-2013, 06:21 PM
Mein Auto: 98 328is
Well from what I could see while it was cranking, the surface that was visible was all smooth. I'll be pulling the head off as soon as it's warmer, way too cold up here right now.
Old 01-26-2013, 06:59 PM
yeah, it should warm up in, what, june, right??
pics when you do....
df
Old 01-26-2013, 07:19 PM
Mein Auto: 98 328is
No no just to a more comfortable near 0 Celsius temperature. It's currently the coldest that it's been all winter.
Old 01-26-2013, 09:31 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Where are you located in Ontario?
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 01-26-2013, 10:06 PM
Mein Auto: 98 328is
Kitchener
Old 01-26-2013, 11:23 PM
ed has a kitchener, he's gonna make tortillas in his....
df
