Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 5 Series > E60 (2004 - 2010)
E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki
Old 01-14-2013, 01:58 AM
Mikechu Mikechu is offline
Mein Auto: 2008 535i
Driver side actuator door lock failure?
2008 535I, Driver side ACTUATOR DOOR LOCK LATCH MECHANISM intermittently works. Sometimes, when I pull on the door handle twice the door does not unlock. I noticed, the mechanism is sluggish, as if it were stuck on something. Is this a quick fix with WD-40 or a showing early signs of mechanical failure? Car is no longer under factory Warranty. Any one how to fix it? Thanks a million
Old 01-14-2013, 07:46 AM
pcy pcy is offline
latch mechanism may just need to be lubed. You may want to remove the interior trim and lube the latch mechanism both from inside, and with the door open.
Old 01-18-2013, 12:02 AM
Thank you.
Old 01-19-2013, 09:42 AM
bighead2267 bighead2267 is offline
Mein Auto: E60 with a turbo
hopefully, we can find the youtube step by step to replace the actuator.
