E90/E91/E92/E93 (2006 - 2013)
Old 01-10-2013, 07:24 PM
loso81 loso81 is offline
Mein Auto: 335i
Seatbelt
my 335i has the thingy that pushes the seatbelt out to you once the car is started, although sometimes the seatbelt doesn't catch on the extension and sometimes it does, on the passenger side it catches everytime i have examined the seatbelts and seems to be no issue but i can't figure out why sometimes the extension catches the seatbelt and other times it doesn't, has anyone else had that problem?
Old 01-10-2013, 07:40 PM
CarlsonTheFlyer's Avatar
CarlsonTheFlyer CarlsonTheFlyer is offline
Paraglide! Walk on air!
Mein Auto: 2010 335i Coupe 6MT
Probably many people have this issue. My drivers side seat belt catches every time, but the passenger side almost never. I have an appointment at Global Imports for an oil change next Tuesday, and since my car is still under factory warranty, I'm gonna have them fix it ( hopefully ).
Carlson The Flyer | BMW CCA # 423862
The problem with common sense is that it's not very common.
2010 335i, ZSP, ZPP, M-Sport, Le Mans Blue, 3 pedals of course!
Heated Seats | USB & iPod | Le Mans Blue | Black Dakota Leather | BMW Performance Kit Stage 1
Previous BMWs:
2001 330i ZSP ZPP 5-speed - sold, but not forgotten.
Old 01-10-2013, 08:03 PM
Mein Auto: 335i
since im still under bmw warranty, do you think this would be something they would/should fix?
Old 01-10-2013, 08:47 PM
David Williamso David Williamso is offline
David W
Mein Auto: 2007 335I E93 & E92
I think they all die after a while, another BMW bad design idea. Both of mine are dead so I just pulled the fuse since the car is off warrantee
David
Old 01-11-2013, 12:14 AM
HKD HKD is offline
HKD
Mein Auto: 2013 335i Titan Silv Red
Knock on Titan silver my seat belt extenders still work at 75 k. Passenger side I had to pull out broken pieces of plastic that was preventing hook from extending out . Brute force and some luck and jiggling brought it back but it's a pretty weak (good idea though ) system.
2013 e92 335i Titan Silver Corral Red
6MT Prem Nav M Sport Comft Access PDC HK Sound Fire Seats
Old 01-11-2013, 12:16 AM
HKD HKD is offline
HKD
And yes if under warranty they will fix or replace it although it may take a visit or two. I did that while it was under warranty.
Old 01-11-2013, 02:14 AM
mfbfreaks mfbfreaks is online now
Mein Auto: E92 320i
Try to iron your belts, bet it will be ok then.
Sent from my GT-I9100 using Bimmer App
Old 01-11-2013, 06:35 AM
Huh?
Previous BMWs:
Old 01-11-2013, 07:24 AM
Mein Auto: 335i
iron my belts? I'm a little confused on that one, lol
Old 01-12-2013, 11:42 AM
AWCoupe AWCoupe is offline
Mein Auto: 2009 BMW 328xi Coupe
I had my driver's side fixed under warranty. Less than $60 in parts if I recall correctly. I always like to see how much a repair might cost me once the warranty is expired. I looked up the part numbers online to get a price. I hated reaching back for the belt. Take it in!
2009 328xi Coupe-Sport Pkg--Cold Weather Pkg-Brushed Aluminum Trim
