Old 01-10-2013, 07:53 PM
tatarogl tatarogl is offline
Mein Auto: n/a
Oil leak source help
Hi,
Can anyone help me identify the source of the oil leak I saw from under the car please? I saw that the oil traces above the steering pump line. I can't see any oil from above the engine (covers off). So I assume its somewhere in the middle. I know Im not loosing any significant amounts of oil because I've been checking it weekly and didnt notice it from the dipstick. I was only aware of it after I crawled under the car.
Attached are some pictures I took from the driver's side and passenger's side from underneath the car. The oil is mostly on the driver's side
Any help is appreciated. Thank you.
ID:	357035   Click image for larger version
ID:	357036   Click image for larger version
ID:	357037   Click image for larger version
ID:	357038   Click image for larger version
ID:	357040   Click image for larger version
ID:	357041   Click image for larger version
Old 01-10-2013, 08:08 PM
Mr745i Mr745i is offline
Mein Auto: 745i
Does ur car have oil cooler or no? I had a couple of leaks and the main one was on the drivers side behind the alternator bracket.
Old 01-10-2013, 08:10 PM
Mein Auto: n/a
Hi, thanks for the reply.
Im afraid I dont know if I have an oil cooler. How can I find out? vin is DR10510 if it helps. Thanks
Old 01-10-2013, 08:27 PM
Mein Auto: 745i
U will have to call ur local dealer and give them last six digits of vin# number and they will let u no if u have oil cooler. If u don't its a good chance that your the seal behind the alt bracket may by worn out.
Old 01-10-2013, 08:30 PM
Mein Auto: 745i
Most common places for oil leaks is, valve covers-front timing covers-alternator bracket seal if not equipped with oil cooler. Cheers
Old 01-13-2013, 06:47 PM
Mein Auto: n/a
Thank you for the help. Do you think I should use any leak blockers before I try to change the seals? and also, do you think I need to change the seals right now or wait until there is significant oil leak? because right now, i cant detect it leaking from the dipstick.
thank you
Old 01-13-2013, 07:01 PM
7Figurez's Avatar
7Figurez 7Figurez is offline
Mein Auto: 2005 745I
No, you should never add leak blocker to this motor it will never run the same again.
Old 01-13-2013, 07:35 PM
Mein Auto: n/a
ok thanks. is there any "more" harm I can do if dont fix the leak yet and wait until it gets worse? I can keep an eye on the oil every week until then maybe?
Old 01-13-2013, 09:01 PM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 745LI/ F02
Agreed!
Old 02-06-2013, 03:14 PM
andreothomas andreothomas is offline
Mein Auto: 745LI
I thought what could be the harm, took my 7 to Toyota just to have the oil changed the other day, now I see leaks, there were no leaks at all on my car. I took it back swears that it had nothing to do with them changing the oil. Go figure!!!
Old 02-06-2013, 03:51 PM
johndade johndade is offline
Mein Auto: 2002 bmw 745li
Why would you take it to toyota for oil change? They most likely dont have the oil you need. And if the tech isnt familuar with bmw oil filter it may not be on properly.
Old 02-06-2013, 04:04 PM
Ultimate745i Ultimate745i is offline
Ultimate745i
Mein Auto: 2004 745i
My alternator bracket seal leaked for 6 months before I replaced it.
It really never got any worse, but I got tired of the burned oil smell and the constant squealing from my belts as the oil leaked down on the power steering pump/hydraulic pump.
Whenever you DO get it fixed, may as well do your driver;s side valve cover gasket and upper timing cover gasket.
Fun Doesnt Come Cheap!
Old 02-06-2013, 05:01 PM
Mein Auto: 745LI
Don't think i'm not kickin myself, just thought oil change how hard could it be for experienced mechanics!!
