Old 01-11-2013, 04:01 AM
hhibmw hhibmw is offline
Mein Auto: 2010 328i Black sedan
Installation of strut brace on E90 sedan
I'm thinking of installing a front strut brace on my 2010 E90 sedan. My question is: Should the suspension be loaded or unloaded during the install? Can the car be sitting on the ground when you do the job? If the brace is non-adjustable, is re-alignment necessary? Thanks for the help.
Old 01-11-2013, 05:03 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
Originally Posted by hhibmw View Post
I'm thinking of installing a strut brace on my 2010 E90 sedan. My question is: Should the suspension be loaded or unloaded during the install? Can the car be sitting on the ground when you do the job? If the brace is non-adjustable, is re-alignment necessary? Thanks for the help.
The brace you want anchors to the center bolt as does stock.
Loaded or unloaded seems to be insignificant until time to torque nuts/bolts. Then, loaded before torque. Unadjustable brace? I wouldn't, but that's me.
Brace looks like a quick'n'easy mod, but should be the last thing you'd do after matched springs & coils, M suspension parts, subframe bushings, and particularly important, a limited slip differential. Have you done all that?
If not purchased yet, M brace recommended.
Old 01-11-2013, 05:09 AM
Thanks, Calwaterboy.........
Old 01-11-2013, 10:35 AM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
Or you could try something like this which doesn't involve the center bolt...
http://www.ebay.co.uk/itm/3905183351...84.m1423.l2649
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof
