The X5 SAV Forum
Old 01-11-2013, 04:14 AM
JNMNL52 JNMNL52 is offline
Mein Auto: 2006 X-5 / 2014 X-5
Labor time to change E53 AC & Alternator belts
Does anyone know a reasonable amount of labor time to replace the belts on and 2006 4.4 E53? Doe the radiator need to be removed?
2014 BMW X-5 xDrive 35i F-15
2006 BMW X-5, 4.4i N62 engine E53
Old 01-11-2013, 09:34 AM
mrbmwx5 mrbmwx5 is offline
Banned
Mein Auto: 06 750Li
45 minutes and the radiator doesn't have to be remove.
Old 01-12-2013, 04:38 AM
Thanks. Glad the radiator can stay in place.
Old 01-17-2013, 02:30 PM
seeskan seeskan is offline
Mein Auto: 05 X5 4.4/05 330CIC
I just did that myself. Radiator stays but you need to remove the plastic cover on top of the radiator, and the cooling fan.
Old 01-17-2013, 02:36 PM
Thanks. how long did it take you?
Old 01-17-2013, 02:44 PM
I am not a mechanic, I am slow and methodic! and it was my first time. I would say it took me 2 hours. If I do it again may be I will do it in 45 minutes.
Old 01-18-2013, 10:20 AM
Mudnyrey Mudnyrey is offline
Mein Auto: X5 3.0i
I hope you have the correct tools to remove the clutch fan? Once removed, just remove the fan cowling and you should be good to go. Just loosed up the tension pulley(s) to remove each belt.
Simple task, just take you time and pay attention on the front main belt in how it's installed.
Regards,
Mud~
Old 02-16-2013, 07:32 AM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
Fan clutch is a left hand thread so as you face the engine from the front, you will turn the wrench clockwise to loosen the fan clutch NOT "Lefty loosey".
Old 02-16-2013, 08:24 AM
There is no clutch on 2006 e53 4.4 . the fan is electric and not attached to the engine. It is clipped onto the rear of the radiator.
Old 02-16-2013, 10:20 AM
I guess Mudnyrey and I both have 3.0i engine and not the V8. Thanks for the correction. That should be a lot easier if you don't have to deal with the fan clutch.
