bmw exhaust ****up - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 01-11-2013, 07:57 AM
windgat windgat is offline
Mein Auto: bmw 525i e34
bmw exhaust ****up
info on bmw 4.0 v8 needed.car misfire and takes long to start.
but i noticed that the exhaust boxes at the front isnt the stock ones but they replaced the 2 boxes with 2 small ones and n mid one plus the origenal back box.so i want to know if you put to much presure on exhaust system does that cause misfire
Old 01-11-2013, 08:07 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
Originally Posted by windgat View Post
I need some information on the 540i exhaust system. I am noticing a misfire and it takes a while to start.
I recently had my exhuast system replaced but I noticed that it isnt the same. The cats at the front seem smaller than before, in addition to a mid pipe resonator, and the original muffler.
My question to you is: "Could these smaller pipes have an effect on the back pressure in the exhaust and cause a misfire?"
^FIXED. Jesus... Help Us Help You
Now, just because the cats and resonator may be smaller or different, doesnt necessarily mean the pipe diameter is different.
Is it a Meineke custom type job? or an OEM replacement?
Is it possible you got a 3.0L exhaust system? Does it differ from a 4.0L?
EDIT: Real OEM shows different part numbers for all three, Catalytic converter, Center silencer (resonator), and muffler
I dont know if they have a different back pressure or if that would cause a misfire...
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 01-11-2013, 08:18 AM
my white bmw 525i has a freeflow exhaust and the consumption is 12.6lt on 100km and the v8 is 31.9lt on 100km.the v8 exhaust there is 2 outpipes on each side that goes into one pipe and on each of them there is a box then that 2 pipes goes into another big box and then into the stock box but that isnt the isue.its the pipes that are welded togeter like my ass.the pipes are wellded shut 60%
Old 01-11-2013, 08:25 AM
Monsignor's Avatar
Mein Auto: Sig
I understand the exhaust system. instead of "box" please use the proper terms so we may help you....
Catalytic converter (Cat)
Midpipe and muffler
How do you weld and exhaust pipe shut?
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-11-2013, 08:32 AM
the black hole repusent the gassflow
Old 01-11-2013, 08:38 AM
Monsignor's Avatar
Mein Auto: Sig
how the holy mother of $hit did that get welded like that
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-11-2013, 08:47 AM
thats the thing.i bought the car like that.the only origenal box that is on that car is the bAck one.its called a pafment job in SA
and now im stuck with a car that idles like **** and strugle to start and i dont know if that could be the problem.and im already low on green.replaced the fuel pump and the 2 filters.cranck sensor.plus when i looked for the o2 sensor there is nothing.so i bought that for show.4 new tires plus the fee for the mechanic that didnt do jack ****
Old 01-11-2013, 08:49 AM
Monsignor's Avatar
Mein Auto: Sig
please proof read your posts before submitting. My generation has allowed me to get used to garble like that so i have the gift (burden) of being able to read it.
Find a junk yard or somebody parting out by you. Buy a used OEM exhaust for a 540 and bolt it up. No O2 sensor will cause your rough start and $hitty idle.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-11-2013, 08:54 AM
and the lack of my english isnt my fault.im afrikaans witch means im dutch.and in SA buying junk yard stuff is the same price as new stuff
Old 01-11-2013, 09:02 AM
Monsignor's Avatar
Mein Auto: Sig
I see, i apologize.
install the new O2 sensor and see if that helps make it run better
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-11-2013, 09:07 AM
no problem.i think im gonna sell
Old 01-11-2013, 09:08 AM
Monsignor's Avatar
Mein Auto: Sig
before that, at least try the O2 sensor...
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-11-2013, 10:12 PM
ill do so.but in the morning she starts like a dream but when the temp rises its a problem
Old 01-11-2013, 11:20 PM
Monsignor's Avatar
Mein Auto: Sig
Sounds O2 related
Sent from Joe's Galaxy SIII via BimmerApp
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-12-2013, 12:52 AM
this is what it looked like
Old 01-12-2013, 01:10 AM
and she starts like a dream now and no ruff idle or misfire.but now i only need to make a plan with the belt because when you drive and you step on pedal it squeks and a shuter somewhere under the car i think its rubers on the diff or something so if you know how i can maybe make it tighter the belt i would apreciate alot
Old 01-12-2013, 09:06 AM
Monsignor's Avatar
Mein Auto: Sig
Thay exhaust is not useable . It needs ti be replaced or somebody who can seriously fix it take a try at it.
Take a look at your tensioners for the squealy belt problem. Maybe post a video
Sent from Joe's Galaxy Tab 2 via BimmerApp
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-12-2013, 10:17 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is online now
Humble E34 lover
Mein Auto: 1992 525i
Check your flex disc and center (carrier) bearing as possible causes for the shudder under the car.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 01-12-2013, 11:10 AM
Monsignor's Avatar
Mein Auto: Sig
+1. Mine is twisted and I have a shudder acceleratung through first gear. Been like that since 96. (My dad liked to hoon it)
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-14-2013, 04:35 AM
BMWFatherFigure's Avatar
Old School
Looks like the OP has found that there is no such thing as a cheap BMW. Shame, but stay with it. Once it is fixed there are no better cars.
Current:
E38 Parts Car
Previous:
Old 01-14-2013, 07:27 AM
Monsignor's Avatar
Mein Auto: Sig
Originally Posted by bmwfatherfigure View Post
looks like the op has found that there is no such thing as a cheap bmw. Shame, but stay with it. Once it is fixed there are no better cars.
+1,000,000
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-14-2013, 07:33 AM
snowsled7 snowsled7 is offline
The Ornery Old Man
Mein Auto: GTI
Yes, beware of 20 year old V8 BMW's for used Camry money. Old BMW's need attention, just like the high maintenance female. Rewards are similar You do not just have to take care of her, you WANT to.
Then again, them make Camry's and Accords by the millions for good reason. How boring and unrewarding...
Good Luck!
Current ride... '13 GTI Wolfsburg
BMW's from my past...
'92 535i/5 '89 325ix/5
'98 750iL '86 325(e)/5
'95 740iL '84 318i/5
Old 01-14-2013, 08:04 AM
Monsignor's Avatar
Mein Auto: Sig
Good Luck!
this. is poetry.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
