Old 01-11-2013, 12:41 PM
JEG23 JEG23 is online now
Mein Auto: 550i
New Function: Activate the optional “LIM” function in North American cars
First for clarification purposes, there are a few types of Cruise Control (CC) systems available:
Cruise control
Dynamic cruise control
Active cruise control (ACC)
Active Cruise Control with Stop & Go function
The pictures I am showing below represent ACC, but the information (and the codes changes) below apply to all CC systems (as far as I know).
In Europe (and perhaps other locations) BMW owners have the option of getting the LIM function in addition to CC. By activating it, you can limit the maximum speed at which your car can actively accelerate to, forbidding you from creeping up in a zone in which you need to stay at a particular speed. This can be very useful, for example, in school zones, areas with high police enforcement or with speed cameras. For some reason, this is not available in cars sold in the US and perhaps Canada.
The picture above shows the typical North American (NA) setup. Button 1 turns on/off the CC, 3 sets the cruise speed and 2 restores the speed (once set). Little known is the fact that the RES button (2) and the rocker switch (5) can also be used to set the speed (by turning it up or down). Once set, (5) can be used to increase/decrease the set speed. This makes, in my opinion, the SET switch somewhat redundant. In addition, if the car is equipped with ACC, there are extra buttons for adjusting (increase (4) or decrease (6)) the distance from the moving car in front.
The setup above shows the system with the optional "Limiter" function. Button 1 also turns on/off the CC system. In this case the RES button (2) or the rocker switch (4) serve as the "SET" button (turn up or down for setting the desired speed, and then up or down to increase or decrease the set speed). The rest of the buttons work as described above.
The "Speed Limiter" is controlled by the LIM button (labeled "SET" in NA), is an independent option, and if activated, it overrides/deactivates the Cruise Control holding speed. When activated you cannot accelerate past the set speed. Think of it this way; CC sets the minimum speed at which you want to travel, LIM sets the maximum. If you do a lot of city driving, I bet you will end up using the LIM function even more that CC.
Note-to activate the LIM function, the CC system does NOT have to be on. Just a simple push of LIM is sufficient.
You can activate this function in NA (and perhaps other locations) by coding the following:
F10
ICM->3000-Daten->LDM_SLD_Funktion-> ein (aus is the default)
ICM->3000 Daten, F8->LDM_Umschaltung_ACC_DCC->zulassen (unterdruecken is the default)
KOMBI->3003 FZG_Ausstattung, 10->SLD_ENABLE->aktiv (nicht_aktiv is the default)
ICM->3000 Daten, F8->LDM_SET_Taste->nur_SET__O (default is SET_und_aktivieren__IO)
F25 (thanks to Sean) & F30 (thanks to ilhan1103)
ICM > 3000 daten, F8 > SLD_Funktion > aktiv (nicht_aktiv is the default)
ICM > 3000 daten, F8 > C_Umschaltung_ACC_DCC > zugelassen (unterdruecken is the default)
When activated, a LIM signal will show up in your instrument panel (see picture below), which is achieved by just pushing the "SET" (now equivalent to the LIM) button on left side of your steering wheel. The limiter can be released (overridden) by accelerating hard or pushing the "SET" (LIM) button again. If it was overridden by hard acceleration, the limit will reactivate once the car slows down to below the set value. When engaged, you can adjust your maximum speed with the rocker switch (4).
As presently configured, you have three redundant ways to set the CC speed (the SET button, the RES button and the rocker switch). With the change in coding, now you will have a new function activated by the SET button (the LIM function) and the rocker switch/RES will be your way of setting the CC speed.
Notes:
Any errors/or malfunctions will clear up after a complete car shutdown.
Functionality on the F25 and other platforms has not been extensively tested. There might be other combinations allowing the activation of CC and LIM. Please let us know if any differences you see.
Thanks to Shawn, Sean (Imsw1), and ilhan1103 for early testing. Particular thanks to Miotoo, whose help was crucial to get this working.
JEG23
2011 550i
Space Gray /Black Nappa, Dark Wood
ZAV, ZCV, ZCW, ZDA, ZP2, 4NB, 5DF, 610, 2VH, 465, 6UK, 5DL, 6NR
Old 01-11-2013, 01:52 PM
Dr.Frankenstein Dr.Frankenstein is offline
Mein Auto: F11 530D
Just a quick correction:
The LIM function does allow you to go above the speed you chose - there is just some resistance once you hit the limit, but if you keep on pushing, you will actually go above the limit.
I do use this to keep me from exceeding 220 km/h, since my winter tires are only specified up to 210... but even with the limit set, I actually have to watch it, so the car does not go faster...
Still very useful - I like it more than the audio limit you can set in the CIC....
Frank
Old 01-11-2013, 01:56 PM
Mein Auto: 550i
Frank
Frank, thanks for the correction.
I do mention that the LIM can be overridden by pressing hard the accelerator. I am sure this is also a safety mechanism, just in case you need to go faster in an emergency.
JEG23
2011 550i
Old 01-11-2013, 01:58 PM
Mein Auto: 550i
Frank
By the way, I envy you. I wish that was my reason to use the LIM function. Usually is for a school speed zone so I do not go faster that 20 mph.
JEG23
2011 550i
Old 01-11-2013, 06:30 PM
kon kon is offline
Mein Auto: BMW
Once the LIM is set, do you also use the rocker switch to set the "max speed"? If yes, means the rocker switch is use to set CC & LIM speed.
Or do you drive up the the max speed and switch LIM on? Means, the rocker switch is strictly for CC use?
Old 01-11-2013, 07:22 PM
Mein Auto: 550i
Kon,
Your first statement is correct. When you are using the LIM, the rocker switch can be used to increase or lower the maximum speed. When you are using CC, the rocker switch is used as usual to set up or down your minimum speed.
The nice thing is that your instrument cluster (or HUD if present) shows these changes in a bright green indicator with the speed.
JEG23
2011 550i
Old 01-11-2013, 08:29 PM
kon kon is offline
Mein Auto: BMW
Originally Posted by JEG23 View Post
Kon,
JEG23
Old 01-11-2013, 08:55 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
Mein Auto: 2011 535i M-Sport
Good Stuff JEG23!
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 01-11-2013, 09:01 PM
Mein Auto: 550i
Originally Posted by shawnsheridan View Post
Good Stuff JEG23!
It is as much yours as it is mine. Heck, let's bring the two bananas back
2011 550i
Old 01-12-2013, 05:53 AM
DreamCar's Avatar
DreamCar DreamCar is offline
Moderator
Mein Auto: Future: F80 M3
That is some effort JEG
+1 for your team work
Old 01-12-2013, 06:51 AM
kon kon is offline
Mein Auto: BMW
Had this activated in my F30 (European model) today, work flawlessly, it originally came equipped with S544A Cruise control with brake function.
Originally, HUD only shows green icon when the Cruise Control is active, show the preset speed briefly then just the icon (if I don't remember wrongly).
For LIM, only the cluster LIM lights up (and the "preset" speed green 'dot' on the speedo, speed adjustment also show on the extended cluster as adjustment is made like cruise control), but nothing shows up on HUD at all - maybe this is a F30 thing, but just wanted to clarify that there is no bright green indicator as you mentioned, at least for F30.
Question I have wondering is, if a vehicle (EU made) only came pre-equip with LIMIT function (no cruise control), would it be possible to also activate cruise control on such vehicle? I'm not sure if there's added hardware requirement (perhaps on the braking part), but at least for cruising it seems possible. Unfortunately, I won't be able to try this out as most vehicle in the country has cruise control as standard option, barring a few parallel (grey) import.
Lastly, would you be so kind to tell me (if you know), what is the setting to fine tune the cruise control/limit speed indicator that appears on the rim/perimeter of the speedo, i.e. the red & green dot.
Mine is working fine except it is indicating/lighting up at the wrong spot, specifically, 3km/h slower, i.e. if I set the cruise control speed at 80km/h, it would light up at the 77km/h spot. No impact to the feature or functionality, just an eyesore. Went to the dealer 3 times to recode to no avail (except replacing the whole cluster which they are reluctant, and promised a new code would fix the problem - well at least for the last 2 to 3 time). I could tell it is 3km/h coz if i set the speed at 83km/h it would lit up the 80km/h spot exactly... hahaha... it was working fine initially, until I send the car in to the dealer for first software upgrade to fix the Auto-Stop-Start that actually ended up as Auto-stall on the first batch of F30/335
Old 01-12-2013, 06:53 AM
tankren tankren is offline
Mein Auto: 116i
+max
Old 01-12-2013, 07:13 AM
Mein Auto: 550i
It was fun.
A lot of very helpful fellows around here.
JEG23
2011 550i
Old 01-12-2013, 07:15 AM
Mein Auto: 550i
Great!
I think it is the same in the F10. The green speed show briefly in the HUD and then disapears.
I highly doubt that you can activate CC by just coding. I am pretty sure you need additional hardware.
I do not know this. I know the codes to allow setting CC at a lower speed than 20 mph for example, but not to calibrate the speed. Sorry.
JEG23
2011 550i
Old 01-12-2013, 09:29 AM
Great!
JEG23
What are the codes to allow setting CC at a lower speed than 20 mph?
- BMWCCA #446923
- flick
Old 01-12-2013, 11:23 AM
Mein Auto: 550i
Shawn,
I am always a bit reluctant to put something out there that I have no tested myself (I am not 100% sure), but here is goes:
For ACC:
ICM->LDM_Wunschgeschw_ACC_max_kmh
ICM->LDM_Wunschgeschw_ACC_max_mph
Hexadecimal values. Convert HEX to decimal and then multiply by 5
Default 180 kmh/100 mph
For DCC:
ICM->LDM_Wunschgeschw_DCC_max_kmh
ICM->LDM_Wunschgeschw_DCC_max_mph
Values same as above
For both ACC and DCC
ICM->LDM_Wunschgeschw_min_kmh
ICM->LDM_Wunschgeschw_min_mph
Hexadecimal values. Convert and use directly
Defaults 30 kph, 20 mph
For the "LIM" speed limiter
ICM->3000-Daten->LDM_SLD_vmin_kmh
ICM->3000-Daten->LDM_SLD_vmin_mph
ICM->3000-Daten->LDM_SLD_vmax_kmh
ICM->3000-Daten->LDM_SLD_vmax_mph
Defaults 30 kph, 20 mph (min) 230 kph, 140 mph (max)
JEG23
2011 550i
Old 01-12-2013, 11:26 AM
Shawn,
For ACC:
For DCC:
For the “LIM” speed limiter
JEG23
Thanks (but you could have tested it damn it)! Put in on the list right after the painfully long awaited 3.18.4 test.
- BMWCCA #446923
- flick
Old 01-12-2013, 11:28 AM
Mein Auto: 550i
Today, I promise.
I would like to test the upper limit, not the lower one
2011 550i
Old 01-12-2013, 11:31 AM
Today, I promise.
Only two violinists? I thought it would have warranted a symphonies worth. At least they play in sync though.
- BMWCCA #446923
- flick
Old 01-12-2013, 01:29 PM
ilhan1103 ilhan1103 is offline
Mein Auto: f30 318d
Great stuff as usual JEG23.
Btw the overruling of this function takes enough time with your foot down on the pedal before it kicks in. So no need to worry you'll bypass it unknowingly.
It saved me from a ticket today!!
Old 01-12-2013, 01:55 PM
Mein Auto: 550i
ilhan1103,
Thank you for your early testing and F30 codes. Now easy on the accelerator!
JEG23
2011 550i
Old 01-12-2013, 06:24 PM
miotoo miotoo is offline
Mein Auto: F10 520d
Well done Jeg23, Im happy to see the result and that it helps others on this side also.
BTW I recently had to drive up to Veendam in Holland from Zurich, thats about 850km each way and most of them on the German autobahn. All I can say is that I just feel love from my Diesel F10 endlessly in these trips. I had the chance to test the cruise at 230km/h but honestly the roads are too busy to be able to keep it for more than a few minutes. Funny that in specs, my entry level 2.0 liter engine isnt supposed to even pass 228km/h, but maybe the engine being at 20K km and running on some premium diesel, it's the only time it will ever be above it's peak advertised performance..I also recently opted for some newly developed low rolling resistance, V speed rated goodyear witer tires, maybe that helps too..the BMW oem winters are not even rated for this speed...
Anyway OT...
Cheers and thanks
F10 520d born 11.04.2011 Deep Sea Blue
205, 230, 322, 403, 415, 423, 428, 430, 431, 459, 464, 465, 494, 502, 508, 522, 524, 534, 548, 609, 614, 615, 620, 644, 654, 676, 698, 851, 879, 962, 1CA, 1CB, 1CD, 2K1, 2PA, 3AG, 4AT, 4UR, 5AC, 6AA, 6AB, 6FL, 6NF, 6NR, 6VC, 8KA, 8TF, 8TL, 8TN, 8V1
Old 01-12-2013, 06:54 PM
Mein Auto: 550i
Anyway OT...
Cheers and thanks
Miotoo,
Thanks to you. Your early help was crucial.
You have no idea how much I envy your ability to push the car to its limit. Here we can hardly ever do that.
JEG23
2011 550i
Old 02-13-2013, 06:56 PM
snj1013 snj1013 is offline
Mein Auto: 2011 528i
Finally got around to trying this and works great. Thanks.
Old 02-13-2013, 07:05 PM
Mein Auto: 550i
snj1013,
I use it every day. Thanks for the feedback
One more tweak. This will make the LIM (SET) button work even better:
JEG23
2011 550i
