E36 (1991 - 1999)
Old 01-11-2013, 04:16 PM
Tkaczuk's Avatar
Tkaczuk Tkaczuk is offline
if it wasn't for that...
Mein Auto: M3, & The Wabbit
Radiator Options.
Currently my E36 has been leaking coolant. I diagnosed it to the radiator and wanted to know if there is a better replacement from the oem rad. Past owner said he has replaced it a couple times and would like to get as much life out of it as possible. I know E36's have weak coolant systems and it would be odd to not have a aftermarket replacement that is of higher quality.
I'm used to E30's where one rad last as long as the car. Any help would be greatly appreciated. Please if your going to be a jerk don't respond.
Old 01-11-2013, 04:36 PM
southpark11235's Avatar
southpark11235 southpark11235 is offline
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
http://www.ecstuning.com/BMW-E36-323...tor/ES1892545/
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 01-11-2013, 05:02 PM
dc_wright's Avatar
dc_wright dc_wright is offline
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Now you have two sources to choose from. ECS Tuning is in Ohio and Bonehead Performance is in PA. Same price, shipping is free, pick which one can get it to you faster.
http://bhperformanceparts.com/mishim.../i-253109.aspx
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 01-11-2013, 07:53 PM
Jakobie1086's Avatar
Jakobie1086 Jakobie1086 is offline
Just a kid with a toolbox
Mein Auto: 330ti
I know everyone hates ebay stuff but the aluminum radiators on ebay are like $120 and they have great welds. I'm 10k and a little over a year in with mine with no issues and I don't suspect any either.
Old 01-15-2013, 12:07 AM
V_323 V_323 is offline
Mein Auto: E36 323i w/ M52B28
FWIW my Mishimoto lasted less than 18 months. The advice I got from the guy at radiator shop when I went to get it repaired was that cheap aluminium radiators are cr@p and to replace with better quality or OEM.
The OEM Behr radiators won't last the life of the car but they are known quantities, fit perfect and will give you a good 10 years before failing. Plus they are affordable and easy to fit.
I ended up replacing my Mishi with one.
Old 01-15-2013, 12:32 AM
Tkaczuk's Avatar
Thanks for the replys. The Mishimoto does have a life time warranty mate. Was kind of thinking about trying out one of the ebay rads. Can always be re-welded right? Turner also has a no-namer that looks promising.
http://www.turnermotorsport.com/p-25...5328323m3.aspx
For anyone who is looking to get a deal on a Mishimoto E36 rad currently $220. Send these guys a email: boombop.racing@gmail.com
Also more info about E36 rads. http://forums.bimmerforums.com/forum....php?t=1276480
Old 01-15-2013, 12:43 AM
Maybe, but know what can not be re-welded, a blown head gasket. Cooling system failure is portably the biggest killer of the e36, so cheaping out is not a good idea.
Old 01-15-2013, 10:07 AM
Tkaczuk's Avatar
Not completely sure. Also have heard of people just finding any old 33mm core rad that would fit and using it with minor modification.
Old 01-15-2013, 10:29 AM
EnserioJose's Avatar
EnserioJose EnserioJose is offline
Back in the game
Mein Auto: 1997 m3
How did it fail?
The shot heard 'round the world.
Originally Posted by E36 Phantom View Post
That presenter is getting waaay too worked up over a tarted up VW Golf.
C:\>Sent from my 386 using MS-DOS__
Old 01-15-2013, 11:29 AM
hornhospital's Avatar
D'oh, You Kids!
Wondering that myself, and why he didn't simply get a new one, since they're warrantied for life.
Quotes to live by:
Old 01-15-2013, 03:35 PM
GeorgeBush234 GeorgeBush234 is offline
Mein Auto: Passat
Where is your coolant leaking from.
Old 01-15-2013, 04:04 PM
Tkaczuk's Avatar
Not sure if I should answer this or not...
Old 01-16-2013, 01:34 AM
Originally Posted by EnserioJose View Post
How did it fail?
It failed where the core joins to the end tanks in October, just started leaking coolant from one of the fins. It was repairable but the radiator shop said I'd likely be back in a few months when it failed again.
I followed up on the lifetime warranty aswell but the E36 ones were on backorder and eta was December, because I needed the car running I ended up forking out for OEM.
Haven't heard anything from Mishimoto so I should get in touch to see where they're at with the replacement.
Old 01-16-2013, 07:01 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
Here is what I installed in my M3:
http://www.turnermotorsport.com/p-18...8is-323is.aspx
Sure it is pricey, but very good quality and great for occasional track use. Plus it is all Aluminum, drops right in (perfect OEM fitment), even takes OEM expansion tank without issue.
Old 01-16-2013, 03:31 PM
Mein Auto: Passat
Dude its just a freaking question all trying to do is help you
