Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects or ask questions about how to fix something on your own. Help fellow Bimmerfest members improve your wrench turning skills! All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 01-11-2013, 07:50 PM
Melina745li Melina745li is offline
Mein Auto: BMW
Red face Heater blows cold air 745 LI
Hey everyone. My 05 745 li is blowing cold air out of all vents when I turn the heater on...the dealer diagnosed it and $736 is not something I want to spend. Is this something I can fix or is it better to have them do it. I hate taking it to the dealer but I heard that it needs to be hooked up to a bmw computer to put it back into drive mode after its fixed and I don't know anybody with one of those. Any help is appreciated as its 27 degrees at night and my booty Warmer won't do the job for long
Thanks !
Old 01-15-2013, 04:23 PM
tommya05 tommya05 is offline
Mein Auto: 325 xi
Heater not blowing warm air
This happened to my '06 3-series the other week. Started happening after coolant hose was replaced. New coolant was added but the system was not bled/flushed correctly (obviously I'm not a mechanic). Fix was super easy ... almost toooo easy???? Synopsys (sp):
Action that Caused Problem:
Coolant not added correctly.
Problem 1:
Residual air in the coolant system.
Problem 2:
b/c air in the coolant system, thermostat valve (valve controls the flow of cooolant to engine) remained in the open position (thermostat's job is to prohibit the flow of coolant to engine until engine reaches a certain temperature, at which time, it open the valve, allowing coolant to flow to engine.
Result of Problems: Coolant is constantly flowing to your engine thus not allowing your engine to warm up to the necessary temperature to deliver heat to the cabin of car. Also, makes your engine run very rich (eg, consume a lot of gas).
Note: (b/c we have different cars, you may have to improvise of modify a little but you should still be able to accomplish the same thing. My car has a square key hole adjacent to the steering column and a start button just above the key hole. To start the car (just a plain old regular start), key goes in key hole, step on brake pedal, and pressing the start button turns over the engine)
THE FIX
Insert key into keyhole. Do NOT step on brake pedal. Press start button. This will cause your climate control system to turn on but your engine stays off. Set your heater to maximum temp on both sides (mine's 84 or 86 degrees), turn fan to the lowest setting (but not off). Step on the gas pedal for exactly 10 seconds (pedal to the metal, baby). Release gas pedal after 10 seconds and let car sit it's current state for 15-20 minutes. Repeat once more if necessary. Completely shut down car (remove key, make sure climate control goes off, etc.) Hopefully car's thermostat/heating system is fixed and the car should be ready to drive immediately.
If this method fails to work but you still insist on having a warm cabin, there's one more fail-proof method: move to the desert (Phoenix, Palm Springs, Arabia, etc); accelerate in vehicle to moderate to high speed; roll down window. If cabin becomes to hot, take shirt off and discard out window.
Seriously though, I have know idea how the gas pedal/high temp, low fan trick worked, but it did.
Old 01-16-2013, 11:28 AM
Mein Auto: BMW
Smile
I'm.trying this right now. Thanks !!
