Old 04-12-2015, 04:14 PM
mcob mcob is offline
Mein Auto: F07, E83, E36 cabrio, E31
configuring sport mode tight steering
I own F07 520d GT –production December 2014- without Integralaktivlenkung and with M Sportfahrwerk. So I have EcoPro, Comfort and Sport modes.
I used to have a F07 530d GT -production date octiber 2010- with Integralaktivlenkung and without M Sportfahrwerk.
In my old 2010 530d it was possible to select in Sport mode i f I wanted to apply it to drivetrain, chassis or both. I used to activate only chassis and I achieved the drivetrain by putting the gear shift in S mode.
The new 2014 F07 could select sport mode, but not configure it
It can be done with 2 codings:
HU_CIC bzw. HU_NBT bzw. HU_ENTRYNAV / MACRO_FDS = popup_and_config put to active
and
ICM / IcmKod_B_Sportindividualisierbar put to active
This way it is possible to code the more stiff steering typical of the Sport mode without the nervousness of the motor and shifting.
Remember to clear codes after you FDL code ICM module; a little bit scaring the error message when you see it first time and don't know that this happens every time you code the ICM module; it goes away as soon as you do the following procedure:
Clear All DTCs/Error codes through ESYS:
1. Connect with your OBD2 cable. AC power only on for your car by tapping START once.
2. Open up ESYS.
3. Select External Applications tab on the left.
4. Select External Application followed by Transmitter.
5. Make sure you connect first with the CONNECT button.
6. Scroll all the way down this list and you will see "Clear All DTCs" at the very end (should be the longest line of them all). Double click it and it will start clearing your codes.
7. Disconnect with the button, close ESYS and shut off your engine. Wait for 30-60 seconds, turn your engine on.
Thanks, manuel
Old 10-15-2016, 12:46 AM
TheBlackGT's Avatar
TheBlackGT TheBlackGT is offline
That Guy w/ the Modded GT
Mein Auto: BMW 550i GT LCI
and
2. Open up ESYS.
Thanks, manuel
Bringing up an old thread. So this allowed you to configure the Chassis and/or Drivetrain in Sport mode? Did it also bring back Sport+ or no?
Say Goodbye to the Old GT. Say Hello to my New LCI.
Different. Bold. Unconventional.
Follow me on Instagram at: www.instagram.com/TheBlackGT
CCA Member: 477510
Old 10-15-2016, 03:04 AM
Yes, it this allowed meto configure the Chassis and/or Drivetrain in Sport mode
but no Sport+
manuel
but no Sport+
manuel
error, f07, f10, icm, steering. sport mode
