unlocked OBC, but cant test while running? - Bimmerfest - BMW Forums
Old 01-12-2013, 08:01 AM
Studawg's Avatar
Studawg Studawg is offline
Mein Auto: 2003 540iT M Sport
So I unlocked it, and checked my coolant temp with the car off, but how do you check the temp and other data with the car running???
Old 01-12-2013, 08:21 AM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
The same way.
Sent from my LG Revolution 4G using BimmerApp
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 01-12-2013, 08:29 AM
Studawg's Avatar
Thanks, all the instructions I read said the key had to be in position 1.
Old 01-12-2013, 08:45 AM
I Am The Machine
Nope, works just fine in 2 as well. Exception is you can't do the cluster bulb test while driving for obvious reasons.
// Chad //
You're a derbanana
Old 01-12-2013, 09:16 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
The readout resets every time you turn off the ignition. So, to read parameters whilst driving, first start the engine, and then activate the readout and call up the parameters of interest. They'll stay up there all the time the engine is running.
Warning messages will not be displayed, however.
Old 01-12-2013, 09:52 AM
rdl rdl is online now
Mein Auto: 530i 2003
There is a trick you can use to cross check the 2 thermistors in the dual temp sensor in the engine.
Start the engine, unlock the cluster and step through the menu to engine temperature. Turn the engine off by turning the key from the "2" position to "1" position but not the "0" position as to remove the key. The unlocked cluster test stays active in the display, but the reading at position 1 will likely be different from 2 by a degree or two. You can toggle between 1 & 2 to see them swap. Works hot engine or cold.
It there is a significant difference between the readings, it's time to change the DTS.
Apparently the display is switched between the thermistor that drives the gauge & the temp signal from the DME which reads the other thermistor in the DTS. I've no idea which is which. Nor whether the gauge needle and overtemp warning light share a common input or one is drive by the DME and the other from the thermistor.
Regards
RDL
