Fan clutch kaput? - Bimmerfest - BMW Forums
Old 01-12-2013, 08:16 AM
BigCo540i's Avatar
BigCo540i BigCo540i is offline
The Usual Suspect
Mein Auto: '12 X6 50i
Fan clutch kaput?
With the engine running at operating temperature, I can stop the fan with 1 finger and spin it backwards would you say that the fan clutch isn't working?
Old 01-12-2013, 08:20 AM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
I Am The Machine
Mein Auto: Dreier, Fünfer & Siebener
Nope. It only engages when the car is struggling to maintain operating temperature.
Go drive hard for a bit and pop the hood, try stoping the fan immediately, after one minute, and 3 minutes. Should engage at least at one of those points. But, use a thin newspaper roll, not your finger.
Sent from my LG Revolution 4G using BimmerApp
// Chad //
// 2006 BMW 330i Sport 6MT // 2006 Toyota Highlander Hybrid //
// 1997 Range Rover 4.0 // 1994 Range Rover Classic //
// 1997 Land Rover Discovery // 1998 Land Rover Discovery //
// 2009 Kawasaki Concours 14 // 2006 Kawasaki Ninja 250 //
// 1999 Chevy Tahoe //
Ok...this is getting ridiculous. Someone come buy a few of these things.
Originally Posted by SlimKlim View Post
You're a derbanana
Old 01-12-2013, 09:09 AM
Mikes530 Mikes530 is offline
Mein Auto: 530
+1 VERY important unless you enjoy a trip to the hospital. The fan employs a fluid coupling that progressively engages the fan based on engine temperature.
Old 01-12-2013, 05:24 PM
BigCo540i's Avatar
The Usual Suspect
Coolant temp was 3\4 to red and getting hotter and i could still stop the fan and spin it backwards with the engine running. No way this is normal for a fan clutch.
Old 01-12-2013, 07:04 PM
AV8R4AA AV8R4AA is offline
Mein Auto: 2000 528it 2004 X5 4.4i
Get new clutch and new prop blade.
You got your monies worth .....
Old 01-12-2013, 10:32 PM
Mein Auto: 530
Sure sounds as if it's seen better days. Did your aux fan kick in, it should have at 3/4 on the coolant temp.
Old 01-14-2013, 01:27 PM
BigCo540i's Avatar
The Usual Suspect
No, my aux fan is on my repair list as well.
I went ahead and ordered a new fan clutch with a lifetime warranty from autozone.
Old 01-14-2013, 01:54 PM
I Am The Machine
Those are very different things.
Yes, the fan clutch is bad. As in my first post, it should only engage if the engine is struggling to maintain op temp. If you were idling at op temp it shouldn't be on in winter in most cases. If the temp was at 3/4, hell yeah it should be engaged.
3/4+ is NOT op temp.
// Chad //
You're a derbanana
Old 01-17-2013, 06:47 PM
BigCo540i's Avatar
The Usual Suspect
Fan clutch it was. The one from autozone was packaged as Turflo but the part was actually a Behr.
Old 01-17-2013, 07:23 PM
cn90 cn90 is offline
I have a simpler way of doing this.
With engine hot, place your hand behind the fan, if it blows well (like your living room standing fan at home @ medium speed), then it is fine.
Or hold a piece of paper behind the fan (between the fan and engine), if the paper flaps, then fan is good.
Sorry not to be scientific!
