X3 N52 Thermostat DIY - Bimmerfest - BMW Forums
Old 01-12-2013, 09:52 AM
mekaneck mekaneck is offline
tool
Mein Auto: 2003 325xi, 2007 X3
This really a fairly simple DIY, the only difficult part is working in tight spaces. This should take 2-3 hours if you take your time. You'll need:
  • Either a 3/8" or a 1/4" ratchet
  • Ratchet extensions (at least 6")
  • A universal joint for the ratchet
  • For the hose clamps, I highly recommend an 8mm ratcheting wrench
  • (If no ratcheting 8mm wrench, you'll need a small flathead screwdriver)
  • Large flathead screwdriver for bleeder screw and radiator drain plug
  • A pick with a hook to get the clips off the coolant hoses
  • Jacks/jackstands/etc.
  • 1 gallon of BMW antifreeze mixed with 1 gallon distilled water
  • A 2 gallon or larger bucket to drain the antifreeze in
  1. Get your car up on jack stands or ramps
  2. Make sure the car is cooled down so you aren't draining hot coolant
  3. Open the hood, and remove the plastic air duct between the intake and the air filter. It just pulls out from either end.
  4. Get under the car, and remove the splash shield. There's about 10 M8 bolts and two plastic rivets that have to be removed.
  5. Place your bucket underneath the radiator, on the driver's side. The pink and blue plastic plug is where the coolant will be draining out:
  6. Get a large screwdriver, and unscrew the blue plug all the way out. Coolant will start draining now.
  7. Up under the hood, unscrew the cap from the coolant expansion tank. Also take your large screwdriver, and unscrew the plastic bleeder screw that is next to the cap you just removed. You don't need to unscrew it all the way, 5 turns or so is fine.
  8. Once all the fluid has drained, you can screw the blue drain plug back in the radiator. You'll need your bucket to catch the rest of the fluid that will come out when we start disconnecting hoses. If you really want to get all the coolant out so there is less of a mess, you can remove the plug from the engine block and drain the rest of the coolant. I didn't do this.
  9. Underneath the car on the passenger side, you'll need to get the oil cooler hose out of the way. It just takes one bolt (10mm hex). This is the hose, already pushed out of the way:
    Now you should be able to see the water pump (barely). It is the black plastic piece behind the sway bar:
  10. Now is a good time to remove the wire that is going to the thermostat. I just inserted a small screwdriver into the clip and just pulled the plug out.
  11. Now it's time to start disconnecting hoses. There's 4 hoses that connect to the thermostat. 2 have hose clamps, 2 have retaining clips. I found it easiest to get the hose clamps off using the 8mm ratcheting wrench. There wasn't enough room for a regular ratchet, and there wasn't enough room for a screwdriver either. I can't say much for this step besides this is where you'll spend most of the time. Just remember how you got the clamps off, because you've got to put them back on eventually too.
    For the retaining clips, I found the one on the small hose easiest to remove by getting to it from the top of the engine and reaching down with a hook-shaped pick. For the larger one, I got to it from the underside with the same pick.
    The large hose takes some considerable effort to remove from the thermostat. It has a large o-ring inside of it that is gripping on to the thermostat. I don't have much advice besides pull hard. I removed the retaining ring entirely, because I kept accidentally pushing it back on while I was trying to get a good hold on the hose.
    Keep in mind there will be a bit of coolant that will come out of these hoses when they are removed. Keep that bucket and some rags handy, and wear something to keep your eyes coolant-free.
  12. Once you finally get all hoses removed, you just have to remove the two bolts that mount the thermostat to the water pump. This is where you'll need the 10mm socket, universal joint, and a 6" extension:
  13. You can snake the thermostat out towards the front of the car and then down. Remember how you did it, so that you can get the new one in there.
  14. I hate to use this line in a DIY, but installation is the reverse of removal. There is literally nothing different. My only tip is to get the large coolant hose back on the thermostat, put a bunch of rags or other padding on the metal cross member, and use that as a fulcrum against your forearm. After I figured this out, this gave me enough leverage to pop the hose back on. Don't put the splash panel back on yet.
  15. After all hoses are connected, and the wire is clipped back in, and that cooler hose is bolted back to where it should be, now is the time to fill your coolant back up:
    - Make sure that blue radiator plug was put back in
    - Make sure the bleeder screw (next to the fill cap) is still loose
    - Start pouring in coolant. I needed about 1.5 gallons. You should fill until you see coolant coming out of the bleeder screw area. The expansion tank will be almost overflowing when this happens. This is ok.
    - Screw the bleeder screw back in. It's plastic do don't screw it down tight, just snug. When you feel resistance you are done.
    - Put the cap back on the expansion tank.
    - Get in the car and turn the key on (but DON'T START IT).
    - Set the air to the hottest setting (94 maybe?). Put the fan on the lowest setting (but not off)
    - Hold the gas pedal down for about 10 seconds, until you hear the water pump start up.
    - Set a timer for 12 minutes so you know when it is done. Now is a good time to get back under there and inspect for leaks.
    - After the water pump bleeding cycle is done (~12 minutes), open the coolant cap and top it up. If you have to add a lot of coolant, I would recommend re-doing the bleed process. If you only add a little, you're probably ok.
  16. Put the cap back on the expansion tank, put the plastic duct back on, and put your splash shield back on underneath the car. Remove the jack stands & you're done.
  17. Clean up & wash your hands so that the smell of coolant doesn't taint your beer.
2003 325xi BlackČ
Old 01-12-2013, 11:58 AM
SonicBoom SonicBoom is offline
Gearhead
Mein Auto: 2007 X3
awesome. I'm doing it. I thought I read elsewhere i=on here that it was a nightmare, but this does not make that seem so.
May I ask what kind of coolant to use? I.E., do us bimmer owners use that 100K crap the American and Japanese cars use?
Old 01-12-2013, 12:44 PM
x3brian x3brian is offline
Mein Auto: X3
Awesome write up!
What symptoms lead you to replace the thermostat? It looks like it is right there with the water pump. I have heard changing the pump is a real you know what. How much more effort is required to do that too?
Sonic - it is bmw blue coolant...very very similar to the g85 coolant that Chrysler uses...just with blue instead of orange die. I change mine every 3 years or so, but they claim lifetime...hahaha
Old 01-12-2013, 02:12 PM
tool
I just used the actual BMW coolant, I bought some from Tischer a while back with another order so the shipping was already covered. It's not all that much more than the Prestone at my local auto parts shop. The cheapest OEM thermostat I could find was from RMEuropean and I googled for a 5% off code also.
I changed mine because I was getting a P0597 code occasionally (more often when the outside temp was below ~20deg F). This seems to have fixed it. The engine temp (via the dash gage) didn't seem any different when I was getting the check engine light, but I went ahead and did this anyway.
Yes, the water pump is right next to the thermostat, but I'm not sure how it is attached to the engine, and I don't know how bad the access is to whatever bolts there are. So I can't say if it is easy or not. But the only thing it would save you is draining and refilling the coolant system. Everything else (remove splash shield, remove cooler hose bolt, remove thermostat bolts) literally takes 3 or 4 minutes. I've only got 50k miles, so I'll wait at least another 30k before I tackle that project.
2003 325xi BlackČ
Old 01-15-2013, 02:30 PM
cagui1223's Avatar
cagui1223 cagui1223 is offline
Mein Auto: 2007 BMW X3 3.0si [e83]
Hey,
excellent post. I also changed the thermostat on my girlfriends 2007 BMW X3 3.0 si due to the SEL returning code P0597. At the time the vehicle had 88,123 miles. I did this back on 11/20/2012. I never posted a DIY because I felt that I didn't get good enough pictures. As you can see its a really tight area to work with.
I'd like to add a bit more information with pictures.
FIG. 1: Beck/Arnley Thermostat | Part #: BEC1430826
Purchased from Auto Parts Warehouse @ $102.23
The two "ribbed" ports (Located at 7 and 9 o'clock) are where the hoses with the hose clamps are connected.
The two other ports (located at 11 and 2 o'clock) are where the hoses with the retaining clips are connected. *** Notice that these two ports have plastic pieces that "jutt" out. So there is only one way these hoses are able to be inserted.***
There are only two bolts mounting the thermostat to the water-pump. Next to the bolts is where the wire connection is located.
FIG. 2: Before removing the thermostat, make sure you see how the original one is connected.
This picture was taken underneath the vehicle, passenger-side.
You'll notice in the picture I removed the two bolts from the old thermostat and placed them on the new one.
FIG. 3: This view is from underneath the passenger-side wheel, looking out towards the front of the car.
FIG. 4: This is a closer view from FIG.3. These are the two hoses with hose clamps.
FIG. 5: Better view of the wire connected to the thermostat and the two bolts mounting it to the thermostat.
FIG. 6: This is what the retaining clips look like.
The Work
There were only a few things I did differently.
1. I disconnected the battery to be on the safe-side.
2. I didn't drain the coolant. Of course I started working on it when the car was cold. Rest assured though that I was drenched in coolant fluid once I started removing the hoses.
3. After removing the oil cooler hose, I unplugged the wire and tucked it in a safe place where it wouldn't get wet. I then I removed the two bolts holding the thermostat to the water-pump. This gave me the freedom to move the thermostat around to gain better access to each one of the hoses. It did require a lot of pulling and tugging to get each hose disconnected, but it is do-able if you're determined!
Don't forget to properly seat and secure each hose. Don't forget to reconnect the retaining clips!
I refilled with coolant, took a few times to get it topped off. Let the car run and checked for leaks, also kept an eye to make sure the car did not overheat.
Last, I went to auto-zone and I cleared the codes.
Its now 2 months later, the SEL has not turned on and the car has not overheated.
Last thing,
the car never overheated to begin with. I never would've known there was an issue with the thermostat unless the car gave out the P0597 code. Anyone can get this done as long as you have the tools to do it.
ID:	357817   Click image for larger version
ID:	357818   Click image for larger version
ID:	357819   Click image for larger version
ID:	357820   Click image for larger version
Old 03-23-2013, 11:12 AM
wil33562 wil33562 is offline
Mein Auto: 2007 X3 / 2007 335i
Hi Cagui1223 & mekaneck!
Thank you for the steps to replace the thermostat. I did mine earlier this week in my 07 X3. I do have one quick question though about the bigger hose coming from the radiator to the thermostat. Once you put the retaining clip back in, should there be in movement in the connection of the hose to the thermostat? I can wiggle mine just a hair. I've only driven about 8 miles since I replaced it and have absolutely no leaks or seepage that I can find dealing with coolant. I might be over concerned though!
Here was my experience of this tasks:
I've always changed my own oil, spark plugs, differential fluids, and transfer case fluids in the X3 so I felt pretty comfortable about taking on this tasks. This was by far the hardest DIY that I've completed. It is fairly straightforward, but those hoses just don't want to come off easily.
I removed the bigger hose with retaining clip first and then the two hoses with the hose clamps next. I was able to get both of the hose clamps off going through the passenger side suspension components. The bigger of these two hoses I was able to use a 6mm socket and extensions to get the hose clamp off. The small of these two hoses I had to use a 6mm wrench.
I saved the last hose with a retaining clip to the end. Once I unbolted the thermostat from the water pump, I was able to get the thermostat out of it location and had enough play in the final hose to move the hose with the thermostat. Once I got the thermostat totally below the vehicle I was able to remove the retaining clip and disconnect the hose. I then reconnected this hose and retaining clip to the new thermostat and fished it back into the recess. I then mounted the thermostat to the water pump.
I was then rather easily able to get the two other back hoses on from the suspension area and clamped down. The final hose was the bigger hose with the retaining clip. It was really tough to get back on. I was finally able to force it back on and the retaining clip fell off. It took about 30 minutes, but I was finally able to get the retaining clip back onto the hose to lock it in place. I did notice just a hair of give when I try to move the hose with the retaining clip in place. It appears to be locked in though.
I then put the new coolant in and bled the system. So far I've driven about 8 miles and do not have any leaks.
Back in November 2012, I had my X3 towed to the dealer due to not starting. It turned out to be a bad fuel pump. The dealer also said that my thermostat was not operating correctly and the DME was not getting a signal from the thermostat. I declined for them to replace the thermostat since they are designed to fail in the open position. However, I did notice through the winter that it would take 25 minutes or so for my heat to really be warm inside the vehicle. After replacing the thermostat, it now takes about two minutes for the vehicle to start blowing hot air with the heat on.
Old 03-23-2013, 12:25 PM
cagui1223's Avatar
Thank you for the steps to replace the thermostat. I did mine earlier this week in my 07 X3. I do have one quick question though about the bigger hose coming from the radiator to the thermostat. Once you put the retaining clip back in, should there be in movement in the connection of the hose to the thermostat? I can wiggle mine just a hair. I've only driven about 8 miles since I replaced it and have absolutely no leaks or seepage that I can find dealing with coolant. I might be over concerned though!...
I can't recall whether or not those hoses gave way. I just made sure they were in all the way and the retaining clip was properly seated in place. I think as long as you don't have any leaks you should be fine.
Hopefully other members with more experience may best answer this question for you.
Old 03-24-2013, 05:05 PM
mhughett mhughett is offline
Mein Auto: 2003 530i/2007 Z4 Coupe
This job is a major PITA, especially if you are replacing the water pump too. There is very little access, either from the bottom or the top. I'd hate to just replace the thermostat because to get to the water pump at a later time, you have to first remove the t-stat and then remove the WP. If you have more than 50k and need to replace your t-stat, unless you aren't planning on keeping the car much longer, I'd recommend you do both at the same time. I know the part is expensive (about $350 from BMW dealers on ebay) but the idea of doing this work again later is a non-starter with me.
2003 530i 5-speed, SP, PP, CWP, Xenon
Bilstein Sports
UUC short shifter with DSSR and ZHP shift knob
Michelin Pilot Sport A/S
BSW IQ speakers, Sirius
CDV delete
Huper Optik tint
2007 X3 3.0si
6-speed manual, CWP, Xenon, Cft. Seats, Premium Pkg, Sirius, Privacy glass
Old 06-09-2013, 08:40 AM
m3davidb m3davidb is offline
Mein Auto: 1995 M3. 2007 X3
Thanks to the contributors of this thread I was able to replace both the thermostat and water pump in my 2007 X3. I just have a couple of things to add:
1. Remove the electric radiator fan (simple task). This gives you a lot of space to work from above. It makes removing the quick connect hoses easy, gives better access to the top bolt of the water pump and you can pull the old units out from the top no problem.
2. Don't try removing them both as a single unit. Pulling the thermostat out first makes it easier to get a socket + extension on that top water pump bolt. I disconnected the U shaped hose between the two at the thermostat and left it attached to the water pump.
Old 06-11-2013, 09:25 AM
Grabby544 Grabby544 is offline
Account closed at users request
Mein Auto: 2009 X3
Re: X3 N52 Thermostat DIY
This is one B.A. thread, thanks gents!!
Sent from my ADR6350 using BimmerApp mobile app
Old 06-11-2013, 09:56 AM
Gearhead
Mein Auto: 2007 X3
Do we have a thread for a cooling system overhaul?
Old 09-10-2013, 01:16 PM
dbz426 dbz426 is offline
Mein Auto: x3
I think that is good idea.
How do we remove the electric radiator fan?
Old 09-10-2013, 06:09 PM
I don't recall exactly but it was pretty straightforward. You remove the plastic cowling on the top of the radiator, disconnect the electrical connectors for the air quality sensor on the top drivers side of the fan and the fan itself, remove a couple of screws holding the fan in place and lift it out.
Old 01-27-2014, 05:41 AM
BigChuckC BigChuckC is offline
Mein Auto: 2007 x3 si
This thread helped me tremendously! The only extra thing I did was take off the front right wheel so I had more room to work. I had more difficulty getting the hoses off with clamps as opposed to the ones with clips. This is a very tight work space and if you have big hands you will be at a disadvantage. The step by step laid by mekaneck is legit!! Thanks!
Old 07-30-2014, 07:08 PM
tool
Just a follow-up to this thread... I unfortunately had to do this basically all over again a few weeks ago, because my water pump failed (I only replaced the thermostat the first time). I took m3davidb's advice and removed the radiator fan this time. Took about two minutes to get it out, and gave me a whole lot more room to work (and see).
I think if my thermostat failed again, I still wouldn't do the water pump at the same time unless they both had a lot of miles on them. It's just not that difficult of a job, especially with the radiator fan out of the way.
2003 325xi BlackČ
Old 07-30-2014, 11:56 PM
ktfaut ktfaut is offline
Mein Auto: X-3
eyeopening
Thanks to Mekaneck and the other gentlemen that contributed to this thread. I replaced the water pump and low-temp thermostat on my 2000 boxster, and it was cake compared to what has been described in this thread. But the brilliant descriptions given in the thread offer excellent incentive to tackle this project.
My wife's '07 X3 keeps throwing that 0597 code, and I also have a cracked coolant expansion tank. Wifey wants dealer to handle it as I lack the time right now. But if the code comes back, I'll follow the fantastic details in this thread to change my T-stat and WP. Thanks again all.
Old 07-31-2014, 11:50 AM
swampX3 swampX3 is offline
Mein Auto: bmw++many
a good don otto bav link
some good tips in these
Old 07-31-2014, 12:20 PM
Mein Auto: X-3
utube
The Bav Auto link to Don Otto - excellent, thanks. Gives hope and confidence to DIY'ers.
Old 11-09-2016, 10:19 PM
canadansk canadansk is offline
Mein Auto: 2007 X3
Just ran through this on by 2007 X3. The process was good and easy to follow. I will agree with whoever it was that suggested to take the fan off - it made removing and replacing the housing quite easy (pulled it out towards the radiator and up), and made attaching the two 'clip' hoses much easier, while the two 'clamp' hoses were attached from underneath the car. It did take somewhere in the 4 hour range, but getting the 'clip' hoses back on definitely took the longest time for a single task. I ended up using a short length of wood, with the top on the hose clip end, the middle pressed back against a metal cross member and the bottom being pulled on with a lot of force by myself. I saw no need to take the passenger tire off.
Old 11-10-2016, 04:39 AM
dukedkt442 dukedkt442 is offline
Mein Auto: 08 E83; '86 442; 84 GMC
Removing the fan should be SOP every time the hood is opened to do any job more intensive than an oil change.
Old 11-11-2016, 04:47 PM
AaronPDX AaronPDX is offline
Just did this. Big thanks to the OP for the instructions! It was a big help. Overall, it took me about 4 hours, with a lunch break in between removal and installation. +1 on removing the fan - this job (and many others) would be even worse if you leave it in. Also, the flexible nut driver is essential for the hose clamps. Hose grease was helpful for getting the "quick" connect hoses re-connected. I didn't have to push too hard.
Now for that beer...
diy, n52, thermostat, x3
