E30 (1982 - 1993)
Old 01-18-2013, 06:58 AM
katinky katinky is offline
Mein Auto: 1990 BMW 325 Convertible
E30 back alignment
The rear toe in of my 19990 BMW 325 convertible is not in alignment and my mechanic says there is nothing they can do, car would need to go to a frameshop to change it. Are there any other options??? Anybody else experienced this???
Old 01-18-2013, 03:16 PM
downhiller's Avatar
livin large
how far off is it?
Old 01-18-2013, 06:00 PM
rear toe in alignment E30
left toe -0.45 deg should be 0.18
right toe -1.29 deg should be 0.18
total toe -1.75 deg should be 0.37
Old 01-18-2013, 06:11 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
That toe is high, but not really enough to warrent correcting in my opinion. It is likely to be caused by worn suspension bushings and/or excessive lowering.
If yu do want to fix it, your best bet would be to replace the suspension bushings which should bring it closer to spec, or if you dont want to take the gamble, search e30tech, there is a member there selling plates that can be welded onto the rear frame and use E39 M5 ecentric bolts that can be used to adjust the camber and toe.
E30 above Sold
Last updated 2nd January 2014
Old 01-18-2013, 06:16 PM
car was never lowered and i had "new" (that is used) trailing arms (wishbone) installed as well as a new left axle. I guess I can have someone look at the bushings. Thanks!!!
Old 01-19-2013, 05:33 PM
downhiller's Avatar
livin large
what did you hit?
