E36 (1991 - 1999)
Old 01-14-2013, 11:15 AM
jjb328 jjb328 is offline
Mein Auto: 1996 328i
Question Transmission light on, manual transmission
Hi, I just bought last week a 96 328 with a 5 speed. The auto trans warning light is on. Does this have a meaning for the manual trans? Could it just be a short in a vestigial sensor wire?, how can I turn it off? Thanx for your input-james
Old 01-14-2013, 11:23 AM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Must be a converted auto car. A 5-speed car wouldn't even have an active socket for that warning light.....
or the cluster's been swapped.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
Old 01-14-2013, 11:25 AM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is online now
King of the Ballers
Mein Auto: Dreier, Fünfer & Siebener
Sounds like your car was originally an auto and was swapped.
Go here: http://www.bmw.com/com/en/owners/acc...catalogue.html and click the link to the right of the instructions (under related topics).
Login with the login info in that link, then click Start by WebETK. Enter the last 7 of the VIN and click the arrows, then along the top grey car select Options. This brings up your cars original build sheet. Click the + by Vehicle Information, if transmission shows AUT it was originally an auto, MECH was manual.
Each window is a new popup, so turn off your pop up blocker and be prepared for a ton of windows or tabs.
Sent from my LG Revolution 4G using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium //
E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. .
Originally Posted by SlimKlim View Post
You're a derbanana
Old 01-14-2013, 12:11 PM
Thanks chad, very helpful
Ok, ive checked my cars build sheet. Its a manual originally so the cluster has been changed. Is it difficult to pull the cluster and remove the led for this warning light?
Old 01-14-2013, 12:24 PM
mgoods50 mgoods50 is offline
OBDI Junkie
Mein Auto: E36 M3
Best way is to code cluster to car, then tell the required modules the car is a manual. This is the only real way to deal with the issue. I would not pull the cluster and do it the hack way.
It's not what you buy, it's what you build- Unknown
EN90283 - Stabled for HG repair
DH06247 - Running like a champ
Old 01-14-2013, 01:12 PM
D'oh, You kids!
It's not an LED, it's an incandescent bulb. Just pull it out. That's hardly a "hack".
Quotes to live by:
BMW-CCA #441426
Old 01-14-2013, 01:15 PM
OBDI Junkie
Mein Auto: E36 M3
Seems like putting tape over a CEL to me.
Old 01-14-2013, 01:20 PM
D'oh, You kids!
No, he's getting an automatic transmission warning light for something that isn't there. Just remove the bulb, since it's purpose is moot in a manual transmission car.
I would never put tape over a CEL or suggest someone else do that. Fix the problem to get rid of the light. In this case, it's a false positive, so eliminate the warning.
Quotes to live by:
BMW-CCA #441426
Old 01-14-2013, 01:26 PM
OBDI Junkie
Mein Auto: E36 M3
right, so why not just code the COMBI to the car?
Old 01-14-2013, 01:28 PM
D'oh, You kids!
Fine, whatever.
Remove the bulb: free
Code the cluster: $$$$
Advantage to coded cluster: none.
Quotes to live by:
BMW-CCA #441426
Old 01-14-2013, 01:33 PM
OBDI Junkie
Mein Auto: E36 M3
Ha Ha-- no offense, just a difference in opinions. coding = free for me; I have a diag. laptop. Also, I couldn't sleep at night knowing my car had a bulb pulled. But you're certainly right on the cost factor. If I did not have access to code it myself, I'd strongly consider just pulling the bulb
Old 01-14-2013, 05:33 PM
Thanx for all the great info!
I really appreciate the info! I think i'll pull the light for now
However, I was a bit concerned about the milage shown, so I did a little research. After looking up my production code, I learned my car was a manual with lsd (limited slip diff) which. is awesome because I live in the rockies above 10000 feet. (i also have a jeep gr cherokee). I then found bimmerinfo.com and got good info on the obc. Should I try to reset my odometer or has this likely been done? I do not show a tamper light, like it says it should. By the way, how much for a diagnostic tool for these cars and where to buy? Again my thanx - james
Old 01-14-2013, 05:48 PM
OBDI Junkie
Mein Auto: E36 M3
Hmm. Probably not mileage adjusted, but you could check the title history and see if there are any obvious discrepancies. I know there is an easy way to code that, but I've never done it myself. The mileage is stored in (I believe) two different modules in your car. As far as purchase, I would not want to step on any toes here-- but I make them available on a limited basis-- normally for local friends or enthusiasts. I primarily set up the machine for OBDI, but OBDII is just a cable and a few settings away. Regardless, in your car, you would want to use the underhood port. If you're interested shoot me a PM once you are able to do so (low post count might prevent).
