Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 02-03-2013, 06:53 PM
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
I got it from eBay seller
Oem_parts_only
I can try and get you one if you need let me know. I saw a few just look up the part number.
Sent Via iPhone using BimmerApp
Old 02-04-2013, 10:39 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: Black Sapphire BMW Z4 3L
That certainly looks like corroded terminals and hopefully is the cause, worth checking gaskets as it must have failed somehow, good diagnosis !!!! Well done!!
Does my bum look good in this !
Old 02-04-2013, 11:45 AM
We will see after I install the new one. Hope it solves the problem.
I'll let you all know soon.......
Old 02-06-2013, 05:48 PM
HerbP HerbP is offline
Oem_parts_only
I appreciate the info on the part seller. It is hard to find used parts for a BMW. Most junk yard sellers don't like selling off the smaller less expensive parts. There are quite a few failures for this particular part on the heater system, making me lean towards a new one. It is interesting that the coil is shorting out, not allowing a on vehicle repair.
Old 02-06-2013, 07:42 PM
Herb I got a used one because I don't know 100% if this part is the culprit.
I say this because when I first push the defrost button I here the blend doors moving and for a few seconds I feel lots of heat then it just blows cold air. So I could have multiple issues or maybe keep my fingers crossed this part will fix it. Got the part today in the mail I'll install it soon.
Old 02-09-2013, 06:14 PM
You know what this means? I got heat flowing again!!!!! Yahoooo!!!!!!
Now it's Click image for larger version
ID:	361591 Time!!!!!!
I replaced the heater control valve that I had ordered after finding the shorted solenoid and it worked like a charm.
Thanks to all that helped I love this forum!!!!!!!!!!!
Old 02-09-2013, 06:18 PM
Glad you got it working!
Old 02-09-2013, 06:20 PM
Glad you helped me fix it !!!!!! Cheers!!!!
I owe you a brew!!!
Old 02-10-2013, 03:23 AM
645/333's Avatar
Michael
Good work, and for the benefit of others good diy and diagnosis!!! You can drive upto the North East now and be toasty warm lol
Old 02-10-2013, 07:19 AM
tampamark tampamark is online now
Mein Auto: 2006 650 convertible!!!
I wonder if my heat works? Wait, never mind, I don't need it!
Very nice diagnosis and fix Nitrogen.
Old 02-10-2013, 12:45 PM
gregb's Avatar
gregb gregb is offline
Mein Auto: 2007 BMW 650 vert
Nice fix Nitro! The power of bimmerfest and some good DIY talent.
Regards, Greg
'07 650i vert, creme beige/jet black, sports & cold weather pkgs, comfort access, premium sound, sat radio, Miro M6 wheels, tint, windscreen, triple resonator delete, 5W bulbs, corner bulb delete and m-tec fogs
'11 Acura MDX Advance with Entertainment pkg for the family - no mod's
Old 02-17-2013, 11:58 PM
Ok well thanks to all that helped get my heat back.
Don't laugh but as I first stated I had a small coolant leak toward the back of my engine. I thought the dreaded curse of the coolant pipe had hit. But after I fixed the heater control valve no more leak.
Can it be? Could the valve cause the pressures in certain areas to go high and leak? Very interesting? I looked at the hoses while doing the replacement and one hose was bone dry. What do you guys think???
Old 02-18-2013, 12:04 AM
07 E63650i's Avatar
07 E63650i 07 E63650i is online now
Living in Fast Forward
Mein Auto: 2007 E63 650i
Good job on the fix Nitrogen. I will buy you a beer if we ever meet!
Once a 6'er, always a 6'er.
Old 02-18-2013, 11:28 AM
645/333's Avatar
Michael
Hi I do not know how to do it but you should consider putting this in the DIY section, as it is an excellent bit of fault-finding to benefit others!!!
Old 02-18-2013, 03:46 PM
Thanks 645/333 I don't know how to transfer it to DIY maybe someone else can help with that.
I just can't believe that the leak is gone now to after repairing the valve. It was in 2 different locations. bizarre!!!
