Old 01-16-2013, 06:11 AM
The-Professor The-Professor is offline
Mein Auto: F11 530xD
Hi Shawn,
could you please send me a link to the file with the 48.2 vs. 48.3 PSdZData CAFD changes?
Thanks,
Max
Old 01-16-2013, 06:23 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Originally Posted by The-Professor View Post
Hi Shawn,
Thanks,
Max
Your killing me. You requested this in 3 different threads.
PM Sent.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 01-16-2013, 06:26 AM
PM Sent.
I was planing to "update" incrementally.
Old 01-16-2013, 07:07 AM
Black750ix Black750ix is offline
Mein Auto: 750i Xdrive LCI 12/2012
Smile
Hey Shawn,
best greetings from Germany ! Its the first time being here in this forum and Ive got to tell you, that Im overwhelmed by this special information about coding the BMW cars. I have changed back from Audi to BMW and missed my VCDS possibilities. I guess, you do a great job, nothing equal is being found in german forums about BMW coding.
Is it possible that you send me a link for the 48.3 PSdZData file ?
Thanks a lot...
http://s1.bimmerfest.com/forums/imag...ile3453453.gif
Old 01-16-2013, 07:13 AM
Originally Posted by Black750ix View Post
Hey Shawn,
Thanks a lot...
PM sent. I gather then you already have ENET Interface cable and E-Sys.
Old 01-16-2013, 07:26 AM
Ive got this one and had it in use for my former Audi A8 (4E): http://www.vcdspro.de/produkte/vcdspro-basiskit/
Ill try to use it with E-SYS - or doesnt it work together ?
Old 01-16-2013, 07:39 AM
ilhan1103 ilhan1103 is offline
Mein Auto: f30 318d
If I read it correctly it states an obd to USB cable. You will need an obd to Ethernet cable for esys.
Old 01-16-2013, 07:54 AM
Okay,
than I need this one ? http://codecard.lt/electronics/tools.../prod_651.html
Old 01-16-2013, 09:26 AM
Yes, that would work, but I would buy this one:
http://www.one-stop-electronics.com/...&product_id=21
Old 01-17-2013, 03:28 AM
Thank you for your hint ! In the meantime Ive ordered that item.
Old 01-17-2013, 07:30 AM
RASHID007 RASHID007 is offline
Mein Auto: 2012 335i
I have an F30 335 that had the software updated by the dealership during a service and as such lost all my previous programming.
Can somebody kindly PM me the link to 48.3 so I can fix that this weekend?
Thank you in advance.
Old 01-17-2013, 08:19 AM
PM sent.
Old 01-17-2013, 10:36 AM
black81 black81 is offline
Mein Auto: E87
Can you send meee ,tooo a link for 48.3
Old 01-17-2013, 01:38 PM
PM sent.
Old 01-18-2013, 06:32 AM
Ausfahrt Ausfahrt is offline
Groccery Getter
Mein Auto: E46 325iT/F10 550
Shawn,
Can send me 48.3.
Alex
Old 01-18-2013, 06:44 AM
Originally Posted by Ausfahrt View Post
Shawn,
Can send me 48.3.
Alex
PM sent.
Old 01-18-2013, 10:54 AM
simonchs simonchs is offline
Mein Auto: BMW 118i F20
Unhappy written data does not match read data?
anyone got issue when using 48.3 psdzdata? i've got the following error when code FDL my F20; when i roll back to full set 47.7 psdzdata + 48.1 update files, everything back to normal again.
Code:
Caf's werden gesucht
Tal wird generiert
NCD werden gelesen
FDL CAFD-00000794-04.7A.53 signieren.
Abarbeitung wird gestartet
TAL execution started. [C205]
ExecutionID=2013/01/19-02:12:08.182
[] prepareTALExecution started
[] prepareTALExecution finished
[] prepareVehicleForCoding started
[] prepareVehicleForCoding finished
[FEM_BODY - 40] prepareECUforCoding started
[FEM_BODY - 40] prepareECUforCoding error
[FEM_BODY - 40] finalizeECUCoding started
[FEM_BODY - 40] finalizeECUCoding finished
[Exception - FEM_BODY - 40] Exception occurred: job failed with negative response error:
 code: written data does not match read data
 description: no detailed description available; ECU: FEM_BODY_40_ETHERNET
 severity: ERROR
Timestamp: Sat Jan 19 02:12:12 CST 2013
ErrorCategory: VEHICLE_ERROR ID: 433
Class: com.bmw.psdz.vehicle.connection.util.ResultUtil
ExecutionContext={category=TAL, ecuid=(FEM_BODY,0x40), TA_CATEGORY=cdDeploy, PROGRAMMING_STATUS=prepareECUforCoding}
[] finalizeVehicleCoding started
[] finalizeVehicleCoding finished
[] finalizeTALExecution started
[] finalizeTALExecution finished
TAL execution finished
TAL-Execution finished with status: "FinishedWithErrorInTransaction". [C207]
TAL execution finished. Duration: "5s". [C206]
Abarbeitung beendet
Code:
Transaktions-Report:       Aktion: FDL Codieren
FEM_BODY [40]
cdDeploy ProcessedWithError
   cafd_00000794-004_122_083 Not Executable
Old 01-18-2013, 02:08 PM
Code:
Tal wird generiert
NCD werden gelesen
 severity: ERROR
Abarbeitung beendet
Code:
FEM_BODY [40]
Yes, you are not the only one. There seems to be issues with F20 / F30 connecting at all, or codiing if connected where the car has 48.3 and 48.3 PSdZData is used.
I have no idea why though.
Old 01-18-2013, 08:05 PM
hmm.. will update e-sys to latest version works?
worth to try if there're no idea at this moment
Old 01-19-2013, 01:45 AM
I don't think the E-Sys version is the issue. I am using E-Sys 3.18.4 just fine with 48.3 PSdZData on my F10 with 47.7 on it. If it was the issue, I think it would not work for any chassis. The problem seems isolated the to 48.3 F20 PSdZData used with an F20 / F30 also with 48.3 on it. Hopefully, the next ISTA/P / PSdZData version will correct this.
Old 01-19-2013, 03:33 AM
akiss akiss is offline
Mein Auto: 2016 MINI F54 Cooper S
Thumbs up
Code:
Tal wird generiert
NCD werden gelesen
 severity: ERROR
Abarbeitung beendet
Code:
FEM_BODY [40]
I know the solution to this one! They implemented a new check within PSDZ-data to check if you are allowed to use E-Sys and have a valid EST token for it.
It's not depending on the car type you've want to code, it would work with an older version of PSDZ data, but than your code would be to new...
Andy
Old 01-19-2013, 03:39 AM
Andy
But why does it seem to affect only F20 / F30? I am using 48.3 PSdZData with E-Sys 3.18.4, and with 47.7 on my car, and I am not having any problems?
Does the Code Away.est not pass this validity check?
What is the solution then? A new updated Token?
Old 01-19-2013, 04:01 AM
Thumbs up
There is a specific file in each car type PSDZ data which is used for coding and sending the programming into your car. And this one is checking for a specific class within E-Sys and if it's not the one expected, you'll get this error and that's the ONLY place this error occurs.
Only an older PSDZ data (without this check) or a new token/patch for E-Sys resolves it.
Andy
Old 01-19-2013, 04:11 AM
Andy
Interesting. So you found this in the 48.3 F20 PSdZData I take it. Did you, or can you, check the 48.3 F10 PSdZData, and see if it too contains this new check?
Aside from this error where you can't save FDL Changes, there is a rash of people all of a sudden having issues even connecting to F20 / F30 cars with 48.3 PSdZData. Do you know if this is the same or related issue, or something different altogether?
Old 01-19-2013, 05:08 AM
Yes, I've found a change (they added another check) in PSDZ 48.3 data for F020 only!
Andy
