Old 01-21-2013, 07:16 PM
PeterC4 PeterC4 is offline
Mein Auto: 535xi,328xiC
Originally Posted by cn555ic View Post
Out of all the F series cars that I coded this check engine light appeared only once...Have no idea what it was but after a day the check engine light cleared on its own...I was puzzled to why it appeared in the first place, but in my case I did not even mess with the VO coding...Either way like I said it cleared itself after a day from what the person told me that I coded the car for.
Sometimes when the check engine light goes off, the fault is still there. An OBDII reader will tell you what it is, even if the light is off. It's the best way to know and I have had this on my 535 when after a tune I installed and the gasket around the air box was not installed correctly. I got a mass air flow sensor fault. Even though the light went off, I still read the code. Best to find out what it is.
2012 535xi M-Sport, Carbon Black, Cinnamon-Alum Hex, Exec Pack, Tech Pack, HUD, Damper Control, BMW Apps, Heated Rear Seats, BMS Tune
Old 01-21-2013, 07:19 PM
Originally Posted by shawnsheridan View Post
It does not need to match, but generally speaking the PSdZData version needs to be >= the last ISTA/P version used to program the car.
In some cases you can get away with using an older PSdZData version if none of the ECU's on your specific chassis / vehicle options received an update in the newer ISTA/P version on the car compared to the PSdZData version you are using.
Hmmm, I think I get it. Are you saying if the module you are trying to code was not updated, you can code it with an older version of PSdZData?
Old 01-21-2013, 07:30 PM
ImSW1 ImSW1 is offline
Mein Auto: F10
That is correct. With the latest large update of the 5-series to 48.2 many cars actually left their dealerships with 48.3. The difference between 48.2 and 48.3 was minor and the majority of the ECUs could still be coded with 48.2 because 48.3 didn't update them.
Sean
Old 01-21-2013, 07:40 PM
Sean
Thanks. Now, am I correct to assume if the module you are trying to modify has been updated, then you may not recognize or find it?
Old 01-21-2013, 08:07 PM
Mein Auto: F10
If you are trying to modify an ECU that has been updated to a later i-step which is higher than you have, E-Sys will throw an error at the "read coding data (from memory, may not be exact wording)" stage (see attached picture). You won't be able to modify that ECU until you get updated psdzdata.
Sean
Old 01-21-2013, 09:02 PM
Sean
I see. So, if you have a fully updated PSdZ file then you shouldn't run into that problem. If you do get that error, do you get an irreversible error, or do you just fail to change the code and all is well?
Old 01-21-2013, 09:04 PM
cn555ic cn555ic is offline
The Coder guy in N.Y
Mein Auto: bmw
If you get that error you wont be able to code the car and nothing happens as no codes are written to FDL and all is well..
Call 917-939-4980 Steven
Old 01-21-2013, 11:19 PM
Black750ix Black750ix is offline
Mein Auto: 750i Xdrive LCI 12/2012
Yes, that would work, but I would buy this one:
http://www.one-stop-electronics.com/...&product_id=21
Hello,
can I use this one with E-Sys for my second car - BMW 335i convertible (E93) too ?
Old 01-21-2013, 11:39 PM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is online now
bimmerfest Supporting Member
Mein Auto: 2011 535i M-Sport
Originally Posted by Black750ix View Post
Hello,
No. You need NCS Expert and a K+DCAN Cable for Exx Coding. You can get that cable too frone One-Stop Electronics.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS, EDC, DHP, & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- Mods - M5 343M 20" Forged Wheels / 6WB MFID / 2TB SAT / 4U1 Ceramic / 6NR Apps / PDV 5k Fogs / Rear Fogs / Euro Tail Lights / Cyba Quad Tips
Old 01-22-2013, 01:36 AM
rs84107 rs84107 is offline
Mein Auto: bmw
You need to add the CAFD back to KOMBI and VO Code the ECU:
Connect => Read FA => Activate FA => Read VCM => Left-Click on KOMBI => Click on "Detect CAF for SWE" => Select the CAFD matching your I-Level => Select OK => Right-Click on KOKBI (the ECU itself not the underlying CAFD) => Select CODE.
To determine your I-Level, go to VCM Module => VCM Master Tab => click Read under I-Steps. The I-Step (current) is the one you want to match when you select the CAFD from the "Detect CAF for SWE" options (e.g. F001-08-09-550).
Dont want to be a PITA but i would appreciate if i understood what i did earlier so that I can avoid this in the future and help others..
so whilst programming, i lost the CAFD for kombi.
1) why did i lose the CAFD? is it normal? did i try to programme something i was not allowed to programme to my car?
2) by adding the CAFD back to KOMBI, what was I doing? was I taking an offline binary file and flashing the ECU of the speedo?
3) when i could choose the CAFD file, I had a list of lots of CAFDs to choose from? where are these files from? are they from teh psdzdata? why are they historically saved on my computer? or do the latest versions of psdzdata contain all teh cafd files from previous versions?
I would appreciate if someone could help me understand this a bit better!
thanks a lot!!!
Old 01-22-2013, 02:07 AM
Okay, thanks for this information, but where can I get the NCS Expert ?
Old 01-23-2013, 03:45 AM
sergis sergis is offline
Mein Auto: bmw
Hi Shawn,may I ask for sending me 48.3 link please?
Old 01-23-2013, 04:30 PM
Mein Auto: bmw
Links are down for the moment..
Old 01-23-2013, 08:08 PM
Sorry. I will ask about special China pricing as I know the cost is a much bigger burden for you folks.
Special China Pricing is 155 Chinese Yuan (RMB).
Old 01-23-2013, 08:51 PM
Mein Auto: bmw
It is bad news!
Old 01-23-2013, 08:53 PM
Mein Auto: bmw
Hello Sean. Whether it is possible to include video in movement on HU_NBT? Excuse for bad English I from Russia.
Old 01-23-2013, 09:10 PM
It is bad news!
I'm back in the game, baby!
Old 01-23-2013, 09:11 PM
PM Sent.
Old 01-23-2013, 09:16 PM
With NBT, you can get USB Video by coding the following:
HU_NBT > 3003 > API_USB_VIDEO > both
HU_NBT > 3000 > ENT_CODEC_XVID > aktiv
HU_NBT > 3000 > ENT_CODEC_VCD > aktiv
HU_NBT > 3000 > ENT_MC_VIDEO_SUPPORT > aktiv
See this Thread:
https://www.bimmerfest.com/forums/sh....php?p=7302788
Old 01-23-2013, 09:18 PM
kon kon is offline
Mein Auto: BMW
new host?
Old 01-23-2013, 09:20 PM
Originally Posted by kon View Post
new host?
Same host for now. Turns out it was a Technical Problem with some IP Filtering, and not that I was terminated. So, I'm back up for now, but with a new unfiltered IP address.
Old 01-23-2013, 09:28 PM
Mein Auto: bmw
See this Thread:
Thanks. I meant dvd in movement.
Old 01-23-2013, 09:33 PM
DVD In-Motion for NBT:
HU_NBT SPEEDLOCK_X_KMH_MAX = Werte= FF
HU_NBT SPEEDLOCK_X_KMH_MIN = Werte= FF
HU_NBT VIDEO_HANDBRAKE = nicht_aktiv
Old 01-23-2013, 09:43 PM
Mein Auto: bmw
Thanks I will try.
Old 01-23-2013, 09:51 PM
kon kon is offline
Mein Auto: BMW
could we share the link to those who ask for it? what's the new IP, may I ask?
