Old 01-12-2013, 12:41 PM
ironman ironman is offline
Mein Auto: 530 xi wagon
530xi wagon front end vibration
My 06 530xi wagon has a vibration or shimmy in the front end when I apply the brakes. My frist thought was the rotors. My brake pad sensor indicates the pads are ok for another 21k and after inspecting the rotors they appear to be fine. Could the vibration be caused by the front control arm bushings and if so what is the best way to check them?
Old 01-12-2013, 03:40 PM
BounceNY BounceNY is offline
Mein Auto: 2007 530xiT
Your rotors may be warped. Hard to see by eye.
Old 01-12-2013, 04:46 PM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
As BounceNY stated above, it's not easy to identify warped rotor just by looking at it. Even a minor warp (not noticeable to naked eye) can cause vibration during braking.
If I were you, I'd replace the rotors and go from there.
Control arm bushings can cause vibration; however, I'd bet warped rotors.
Old 01-12-2013, 05:43 PM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
+1
Audio: Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Helix P-DSP, Zapco Z-150.6 amp, CIC iDrive upgrade
Performance: MHD Pro Tune, AR Downpipes, ER FMIC/CP, DCI, RB turbos and inlets, KW V2 coilovers, Fuel-It Stage 2 pump w Ported fuel rail, Mfactory LSD
Old 01-13-2013, 06:02 AM
Thanks for the info! When changing rotors should you to do the pads and sensor as well?
Old 01-13-2013, 06:19 AM
Oceans10's Avatar
Only if they are worn. It's the rotors that warp, pads wear down evenly.
I am having good results with Centric Cryo treated rotors from Tire Rack.
I am using Hawk HPS pads. Much less dust and brake slightly firmer than OEMs. A little less bite on soft touching, but once they engage they are solid. Silent too.
It's good to do a brake fluid flush at 60k miles if you have not done so already. Has nothing to do with warped rotors though.
Old 01-13-2013, 07:48 AM
z0lt3c's Avatar
z0lt3c z0lt3c is offline
what does this button do?
Mein Auto: 08 535xit
Rotors typically "warp" from either heat build up or from pad deposits. Heat build usually leaves discoloration in the surface of the rotor and is easier to diagnose then pad deposits. What brand rotors and pads are you using now? You may want to consider resurfacing your rotors once, this can eliminate warp from heat build up and/or strip off any pad deposits build ups. After the resurfacing, if the shimmy is gone, then obviously you know you are on the source of the problem. Keep in mind that the warp can return if it's caused by failed components such as wheel bearings or incorrect torqued wheels, less likely to return if resulting from infrequent emergency braking. This is why I suggest resurfacing before spending money on new rotors, if the warp does come back you need to start investigating other possible root causes, fix them, then replace the rotors. Another idea to try to switching to a different pad compound, this can help clean up the pad deposits without even removing the rotors. I do not suggest Centric brand rotors on an e61, I've had quality issues with two different sets and could not keep them from warping out, switched to OEM rotors and no problems since. There is a reason why these rotors are so cheap and generally, yes, you get what you pay for.
Old 01-13-2013, 01:33 PM
Everything is OEM at this point.
