Old 01-12-2013, 06:40 PM
daveandamy daveandamy is offline
Mein Auto: 2006 530i
Frustrated...
I recently purchased a used 2006 530i from a small dealership. We discovered an oil leak before signing all the paperwork and the dealers agreed to fix the engine leak. When I went to the mechanic to pick up the car, he informed me that they fixed the obvious leak but the oil pan gasket needed to be replaced as well. The dealer told them not to fix it. I called the dealer out on it and they signed a new contract stating they would replace the oil pan gasket. I picked the car up today after much frustration and just over dealing with these guys. I looked over the car but I'm a girl and 8 months pregnant so just to the point of tears from trying to get this all worked out. The computer shows the oil at only half full and when I dropped it off it was just under full. Is there something that I need reset? They were not happy about having to do the repairs and wouldn't give me receipts of the work but said I could take it to any mechanic and they could see the work was done. About30 minutes after leaving the dealer, I punched the gas to pass a slow driver and the transmission fault came on the computer. Now I'm really ready to cry. I turned the car off and restarted it and it was fine the rest of the trip. Does that mean I have transmission problems?? I love the way the car drives and the interior and exterior are in mint condition. After driving a BMW I don't want anything else! I'm just worried about the repair costs. Any feedback will help. Thank you Amy
Old 01-12-2013, 06:55 PM
UltimateDriving UltimateDriving is offline
Mein Auto: A Car
The oil level sensors in these cars varies a lot. Keep driving it for a couple days/weeks and pay attention to the oil level to see if it needs oil. Even if it shows half full it only means you are down about .5QTS since the Oil Level sensor ONLY calculates the last QT of oil NOT the full capacity of the engine.
Regarding the transmission you could either keep driving it and see if the error shows up again or you can take it right away to a reputable indy to check the codes and see what's going on.
Old 01-12-2013, 10:09 PM
v8power v8power is online now
Mein Auto: 2013 550xi M-sport
The oil leak is a small problem. Usually bad hose or gasket which can be replaced at a reasonable $$. Transmission on the other hand is a complicated problem that will be in the thousands. Sadly to say, walk away if you can. Don't let the excitement overcome the problem. You will realized it in a few days when your joy wears down. Plenty of others around.
2011 X5 35i Sport
2007 E92 335i
Old 01-12-2013, 11:26 PM
wcr3d wcr3d is online now
Mein Auto: 2013 535iX M Sport
You should have a 30 day grace period. With what you have been through so far I'd say take it back. As been stated there are plenty of others around. Good luck!
Old 01-13-2013, 06:07 AM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
If I were you, I'd take it back and put it in writing that trans problem was observed. If that trans problem reoccurs, you have a record to prove.
Prior to buying the car, did you have an independent mechanic do pre-purchase-inspection? When you observed trans fault, diagnostic code may have been set; BMW diagnostic code reader can retrieve that code. That code can reveal more about what the error was.
Old 01-13-2013, 10:23 AM
DAI's Avatar
DAI DAI is offline
Gap Filler for a M6 GC?!?
Mein Auto: '10 550i M-Sport
+1 if your state laws and/or contract allow it.
I'd find a better dealership then and make sure you have a pre inspection done prior to purchase.
Old 01-13-2013, 10:39 AM
I'm taking it back to the mechanic who was honest with me about the leak. Very reputable and trustworthy import repair shop so hopefully what ever damage the dealer's mechanic did will be obvious. I've looked through all my paperwork and I don't see anywhere that I have 30 days but they did default in the time they were supposed to finish the work and they didn't repair the leak (or they caused a new one when replacing the oil pan gasket). Depending on what the mechanic finds, I'll have to go from there. I've already cried over it and that didn't fix a thing! Small claims would be my next step. I could always drive my car through their building and claim it was pregnancy hormones
Thank you for all of your suggestions! I'll keep you posted.
Old 01-13-2013, 02:15 PM
batmbl's Avatar
batmbl batmbl is offline
Mein Auto: 2009 535i
Sorry to say, most used car sales, even in small claims court are "as is" unless you get a written warranty. I wish you the best.
