Old 01-12-2013, 03:19 PM
AutobahnCowboy AutobahnCowboy is offline
Mein Auto: BMW
Acoustical Lock Confirm
Today i tried out
HU-NBT
-- 3000 HMI
--- ACOUSTICAL_LOCK_CONFIRM
Kommentar: Steuert ob die Einstellung zur akustischen Quittierung angezeigt wird und eingestellt werden kann. Konfiguration über FZD/CANSINE
Comment: Manages if Setting for acoustical Lock Confirm will be shown and editable. Config from FZD/CANSINE
For Opening you´ll get 2 annoying beeps and for Closing one
Mercedes does this better, they use the horn for confirmation
After realise that its not really more comfortable i changed back to nicht_aktiv
The Checkbox disappeared, but the beep stays
Tried also "Code" and re-read "Read Coding Data" so all my changes went and "Code FDL" this untouched cafd again, no success
Could someone help how to get rid of this?!
ID:	357359   Click image for larger version
Old 01-12-2013, 07:20 PM
tankren tankren is offline
Mein Auto: 116i
you can change the buzzer frequency and duration to DIY the beep type, maybe in the module FZD(F20)
Old 01-13-2013, 04:59 AM
Mein Auto: BMW
yeah, you´re right
FZD
-- 3001 LIN - SINe
--- Buzzer frequency
--- Buzzer duration
first set Frequency down to 01, then the sound was more acceptable
Frequency changed to FE
Duration changed to 01
on Frequency FF and Duration 00 the sound doesnt appear, but an clack instead from under the car
with FE and 01 its completely silent
Old 01-13-2013, 05:36 AM
Mein Auto: 116i
Originally Posted by AutobahnCowboy View Post
yeah, you´re right
FZD
-- 3001 LIN - SINe
--- Buzzer duration
F20 FZD 3001 LIN_SINE Buzzer level high initwert,level_3 level_10(MAX)
F20 FZD 3001 LIN_SINE Buzzer frequency werte=8F Min 7D~ Max AF
F20 FZD 3001 LIN_SINE Buzzer duration werte=0A Min 01~ Max FF
Old 04-27-2013, 01:55 PM
neide neide is offline
Mein Auto: 2006 530i | 2006 X5 3.0
Thanks for this, mine sounds better than before. Has anyone figured out how to turn off the unlock chime, so I only have the chime when locking?
